Old 05-28-2006, 06:16 PM   #1 (permalink)
Default 98 DISCOVERY FRT WHEEL BEARING disassembly
Dear Land Rover Guys,
How do you disassemble the front wheel bearings on this vehicle.
There are about 8 bolts on the outside of the hub , and a circlip
under the plastic cap. Any help would be appreciated. I need a gasket ,
and inner and outer wheel bearings , as far as I can figure.
Thanks Al
arsoud is offline   Reply With Quote
Old 05-29-2006, 08:01 AM   #2 (permalink)
LANDY96's Avatar
Check your email!
Eric The Red
93 Range Rover Classic
96 DISCO SE7 5-SPEED SOLD
96 DISCO SD 5-SPEED
-ARB Bumper
-OME 2" Lift
-2" spacers
-Safari snorkel
-15" steelies
Old 05-29-2006, 08:31 AM   #3 (permalink)
for any vehicle you take bearings out of the trick to putting it back to gether is lay everypiece out in line in order that you took it apart.
That way everything goes back in the right order.
