99 D1 Brakes - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 3 (permalink) Old 03-20-2017, 02:56 PM Thread Starter
Quoted: 1 Post(s)
99 D1 Brakes
I have a 99 D1 V8 petrol and can't seem to resolve brake issues. New booster, new spacer plate, new proportioning valve, new pads and rotors. Mechanic says brakes were bled properly but the rig won't stop for nothing! Good pressure at the pedal but just doesn't want to stop. Willing to do the master cylinder but scared I'm just throwing money against the wall! Any ideas? Any specifics to the bleeding? I've read other posts and can't seem to find an answer. Also the computer flagged an ABS wheel speed sensor and I replaced that. The error code is now gone. Thanks in advance!
Michael Northcutt is offline
post #2 of 3 (permalink) Old 03-20-2017, 03:15 PM
OFFROVN's Avatar
Quoted: 25 Post(s)
I ran into this once ...(pardon the pun)
My brakes felt like they were wooden brake pads squeezing wooden brake rotors...Fred Flintstone would have been so proud.
My solution was drilled and slotted rotors and Akebono (sp?) ceramic pads....I also eliminated my ABS and went to a adjustable proportioning valve for my front /rear bias....
My opinion would be, a new master would NOT be a waste of money... Also, the booster on my rig was part of the problem a slight vacuum leak made my brakes okay at speed, but weak at idle and off-roading...which is why I sunk my teeth into it ....Proper and patient brake bleeding is also paramount.
Considering STOPPING is about the most important thing a Rover can do...solving the issue at all cost, is imperative.
OFFROVN is offline
post #3 of 3 (permalink) Old 03-20-2017, 03:58 PM
Wounded Knee Moderator
ihscouts's Avatar
Quoted: 77 Post(s)
Another thing most of us do is increase the size of the front calipers with D110's, put's more shoe surface on the rotors.
97 SD - Altai Silver. Sold
94 Saturn SC2
Roverless and wandering
The three-position Lucas switch--DIM, FLICKER and OFF.
The other three switch settings--SMOKE, SMOLDER and IGNITE.
Ultragauge
Contact info for Paul Grant;
203-770-1699
Contact info for Will Tillery;
540-462-7353
ihscouts is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Help Please With Brakes!!! tbone4jc Discovery Series I 10 09-13-2010 02:53 AM
Need Help with Brakes, Please!! Liner1900 Discovery 3 / LR3 7 08-26-2010 09:15 AM
Are Land Rover D1 brakes & rotors interchangable with D2 brakes & rotors? WLADiscoII99 Discovery Series II 3 07-30-2010 07:46 AM
Brakes pilot76s Discovery Series I 8 07-29-2008 05:54 AM
"Fiddle Brakes" (AKA Cutting Brakes) Mark HH Discovery Series I 2 06-17-2006 02:05 PM
You may post new threads
You may post replies
