Old 09-14-2006, 04:13 PM   #1 (permalink)
JesusIsLord
9dawgs's Avatar
Gallery: 2
Default '99 D1 Fuel Pump Relay Location???
I just got my relay in the mail from Atlantic British to see if this is the fix for my intermittant starting problems on my 1999 D1 with a 4.0. I went to the truck to "pop it in" and I can't locate the relay! I looked in the right kick panel and saw several relays (yellows & green) but none that looked like the new one (black) and nothing close to the part number. I looked under the bonnet on the right fender well and didn't find anything at casual glance. Is it hiding behind the windshield washer resevoir?
9dawgs
'99 Discovery I
'99 Chevy Astro 4X2 w/4" Lift (family truckster)
17' Basstracker w/40HP Mercury
11' Jon Boat w/numerous antique outboards
9dawgs is offline   Reply With Quote
Old 09-14-2006, 04:50 PM   #2 (permalink)
mac55's Avatar
It's Behind the RH footwell trim panel!
mac55 is offline   Reply With Quote
Old 09-14-2006, 05:23 PM   #3 (permalink)
JesusIsLord
9dawgs's Avatar
Gallery: 2
I aready checked there Mac55. All I saw was about 3 yellow relays and one green one. Which one is it?
9dawgs
'99 Discovery I
Old 09-14-2006, 09:33 PM   #4 (permalink)
mac55's Avatar
The disk shows it to be about the middle one! maybe marked K119!!!
Old 09-14-2006, 10:05 PM   #5 (permalink)
mac55's Avatar
Default here's a pic!
99-d1-fuel-pump-relay-location-fuel-relay-location2.jpgGood Luck!!!!!!
Old 09-15-2006, 07:13 PM   #6 (permalink)
JesusIsLord
9dawgs's Avatar
Gallery: 2
Ok, I've had my head in the RH kick panel about a dozen times now. The relays in there are all yellow with one being green. My RAVE cd says the Fuel Pump Relay for my vehicle should be located there and have a blue base. There is no relay in there with a blue base...
The photo in the reply above shows what the diagram on the cd shows but it's not the same. Can someone with the same vehicle or maybe a LR mech on this forum give me a little help here?
9dawgs
'99 Discovery I
Old 09-16-2006, 02:51 PM   #7 (permalink)
JesusIsLord
9dawgs's Avatar
Gallery: 2
Default Final Solution...
Ok, for anyone who is interested. I finally discovered why I couldn't find the fuel pump relay in the RH kickpanel. It's because it's not there... In the '99 D1 the fuel pump relay is in a Multi-function package and is located in the engine compartment next to the fuse box. I found this out by cross referencing the part number with what I had in hand with a site called Britcar (UK) Ltd.
Come to find out the part I got from Atlantic British was for '94-'95... When I ordered it from Atlantic British 2 weeks ago they didn't have the year model posted on the parts catalog so when I looked up a Fuel Pump Relay for a '99 D1 what came up was what I ordered. The difference in price was about $60. The new multi-function relay will arrive in a few days...
9dawgs
'99 Discovery I
Old 09-17-2006, 07:49 AM   #8 (permalink)
mac55's Avatar
That's great!!!!
Sorry to miss led you !!!!
Old 09-17-2006, 08:25 AM   #9 (permalink)
Sounds like Rover was using a 99 D2 wiring system on the last of the 99 D1's.
Old 09-17-2006, 03:43 PM   #10 (permalink)
JesusIsLord
9dawgs's Avatar
Gallery: 2
That's great!!!!
No apologies needed. This is a learning process for most of us. That's why this board is so important...to me at least!
9dawgs
'99 Discovery I
