Old 08-13-2007, 09:43 AM   #1 (permalink)
Default ABS issue (argh ABS is hard to search for)
sorry i tried searching for this, but ABS is too short
so anyways, my "Anti-Lock" light doesn't turn off sometimes after I start driving, and more recently it has started pulsating the brake pedal even when not necessary keeping me from being able to stop. (only when trying to brake)
Letting off the brakes and pressing again allows me to continue braking as normal, but its scary!
Anyways, I'm thinking a sensor is malfunctioning? Anyone have this problem before?
Is changing an ABS sensor fairly cheap and an easy DIY?
For the time being i have disconnected the ABS fuse to keep it from going off when not necessary (im talking 25 MPH approaching a stop sign under dry conditions)
boon4376 is offline   Reply With Quote
Old 08-13-2007, 09:44 AM   #2 (permalink)
Elemental's Avatar
Did you pull the codes yet?
Old 08-13-2007, 10:02 AM   #3 (permalink)
96 Disco
rovermech's Avatar
Go around to each wheel and tap on the top of each sensor and make sure they are seated in all the way.
rovermech is offline   Reply With Quote
Old 08-13-2007, 03:24 PM   #4 (permalink)
oh sweet, i didn't know there were ABS codes
and can a bunch of oil / sludge coated over that area throw off the sensor? because I'm leaking something down there and its thick. i'll try decreasing the area tonight.
Old 08-13-2007, 03:29 PM   #5 (permalink)
Elemental's Avatar
http://www.discoweb.org/forums/showthread.php?t=13968
Here is the proceedure to get codes.
