Old 05-24-2005, 09:06 AM   #1 (permalink)
Default ABS light
my abs light came on in my D1. what usually causes that? any way to reset it?
rov'n is offline   Reply With Quote
Old 05-26-2005, 09:38 AM   #2 (permalink)
Default Abs
G'day Mate,
This is a common problem on Disco's. The ABS system on these cars is very sensitive and ANY problem will bring the ABS warning light on.
1, Check all the fuses (Not just the ABS fuses but all of them,)
2, Check the brake/stop switch and make sure it is working, if not check to see if its getting power.
3, Check the sensors on the wheel hubs, MAKE sure that they are firmly seated in the hubs and not loose. While you are there, check for any play in the bearings, this can affect the sensor rings.
4, Get an Ohmmeter and check for continuity on ALL of the sensors, there are 4 but the rears are linked ( the readings should be around 1000 ohms)
If all of these check out then, sadly its dealer time. A magic black box is needed to get the fault codes. I had some big headaches with my D1, Did everything but check the brake/stop light switch and sure enough that was the fault. Once it was replaced the fault went away but the car still needed the magic box treatment for the light to go out. I know that if the sensors are loose the ABS light comes on intermittantly, pushing them firmly in will fix it and the light will go off once you get over 5mph.
This is just a an idea as to what to do, these systems are really sensitive and there have been some real horror stories on this website.
Good luck Mate.
Wes DownUnder
Wes DownUnder is offline   Reply With Quote
Old 05-26-2005, 09:47 AM   #3 (permalink)
Default Admin?
Just a quick note to the Admin,
The ABS fault on Disco's (D1) seems to be a regular happening, any chance that we could have to page just for it/and other common faults?
Luv n' kisses,
WesinOz
Old 05-26-2005, 06:20 PM   #4 (permalink)
looks like i have a sensor out maybe, it rained today so i thought i would just jump on the brakes and see what one locked up...well it was the front passenger side that did it...how what do i check before i go about tearing things apart?
Old 05-27-2005, 08:16 AM   #5 (permalink)
Default Same Problem
I also have the same problem with the ABS light but I am not very mechanically minded!
Could anyone give further directions to the brake/stop switch??
Any further help with this problem would be most welcome!
Thanks!
Beirut_Rover is offline   Reply With Quote
Old 05-27-2005, 08:21 AM   #6 (permalink)
PCrover's Avatar
Changing a front ABS sensor on my '95 D1 was one of the easyest things I have done. You just pry it out of the top of the wheel hub, unplug it in the engine compartment, cut a couple of cable ties holding the wiring in place and remove it. Reverse to install the new one. I Found a used sensor for $50 to replce it with too.
Gary
2001 Discovery II
PCrover is offline   Reply With Quote
Old 05-27-2005, 08:26 AM   #7 (permalink)
You make it sound so easy! How do you think someone who does not know a spanner from a screwdriver would go??
Seriously that doesn't sound too hard.. thanks for the advice!
Old 05-27-2005, 08:51 AM   #8 (permalink)
PCrover's Avatar
Take a look at it before you decide. The ABS sensor is located on the top of the wheel hub on the inside, you will see a wire going into it.
Gary
2001 Discovery II
Old 05-27-2005, 09:53 AM   #9 (permalink)
myhomescape.com's Avatar
Damn....my ABS light came on this morning on my way to work in my D1. Looks like we're in the same boat.
myhomescape.com is offline   Reply With Quote
Old 05-27-2005, 03:34 PM   #10 (permalink)
haha. my light went off when I left work that evening.
It appears that my D1 is self-mending.
Old 06-11-2005, 02:57 PM   #11 (permalink)
I dont have that proplem!!!!
PS:
Disco -90
TDI 200
2"
ARB bull bar
Superwinch
BF_goodrich mub terrain
EMU
-juhani- is offline   Reply With Quote
