The ABS light comes on every once in a while on my son's "98 D1 when he is making a slow (almost stopped) turn. It doesn't do it all the time. He says he can feel the pedal pulse when it happens. Everything else seems OK.
He also has a ratteling sound from the area of the cats. Is there anything else it could be ?? Thanks for any info... PFZ |
#2 (permalink) | |
Sounds like one of the cats is gone (marbles in a can sound). On the ABS reseat the sensors and that should solve the problem. There could be more of an issue but I doubt it! Good Luck!
2006 Range Rover Sport HSE Rimini Red 2001 D2 CDL ![]() 1998 D1 ('Henry' Sold 05/05 Bought Back 01/06 Retired) 1988 RRC SWB ('Silver Bullet' Retired 05/98) |
![]() Join Date: Jun 2005
Does it happen in all weather wet and dry? I have has a sensor go bad causing a similar effect when it was wet.
"Ish...I have in the past mistaken you for a perverted shit bag...now I realise that I am not shit bag enough. You truly are a king among men.I am not worthy with such imagination." Series 3 Guy 2005 Range Rover HSE 2007 BMW X3 M Sport Pkg 1990 911 Cabrio triple black 2006 Mini Cooper S Checkmate - GONE 1987 Corvette - 18 yrs Gone,,, sniff sniff - |
It sounds like the ABS Sensors (one of them) is kicking in prematurely. Which is usually indicitive of a bad/dirty sensor..and they are not cheap! However try to push them back in (clean them too with a steel wool pad), flush the brake system with Dot4, and see if that solves it..Donuts to Dollars it is one of the front sensors.
I cleaned the ABS sensors on my son's car Sun morn before he took off back to Kansas City. They seemed tight and OK. I noticed that the springs between the pads on both sides were broken and replace them with some generic springs from hardware store. I also bled the four wheels and checked pressures. He called when he got back and said "NO light !!" but like I mentioned, it only happens sporatically. When you only have a couple of hours to get everything corrected, you can't dig too deep !!! With six other cars to maintain, I'm sometimes pressed for time to get ALL jobs accomplished... I also have a real job !! Cars and racing are my only time consuming HOBBY !!!
PFZ |
Mod. --- I'm watching you
I would think the heat shield on the exhaust is broken.
Just weld it back up or cut it off and wrap the pipe or cat in heat tape.
-John Some of my favorite quotes: "what you do in life, echo's in eternity..." "death smiles at us all... all a man can do is smile back..." 1999 Discovery II SE-7
