Old 08-21-2005, 12:48 PM   #1 (permalink)
Default ABS light
The ABS light comes on every once in a while on my son's "98 D1 when he is making a slow (almost stopped) turn. It doesn't do it all the time. He says he can feel the pedal pulse when it happens. Everything else seems OK.
He also has a ratteling sound from the area of the cats. Is there anything else it could be ?? Thanks for any info...
PFZ
pzwerner is offline   Reply With Quote
Old 08-21-2005, 06:20 PM   #2 (permalink)
RoverChic's Avatar
PFZ
Sounds like one of the cats is gone (marbles in a can sound). On the ABS reseat the sensors and that should solve the problem. There could be more of an issue but I doubt it! Good Luck!
2006 Range Rover Sport HSE Rimini Red
2001 D2 CDL
1998 D1 ('Henry' Sold 05/05 Bought Back 01/06 Retired)
1988 RRC SWB ('Silver Bullet' Retired 05/98)
RoverChic is offline   Reply With Quote
Old 08-21-2005, 07:17 PM   #3 (permalink)
ish
ish's Avatar
Does it happen in all weather wet and dry? I have has a sensor go bad causing a similar effect when it was wet.
"Ish...I have in the past mistaken you for a perverted shit bag...now I realise that I am not shit bag enough. You truly are a king among men.I am not worthy with such imagination."
Series 3 Guy
2005 Range Rover HSE
2007 BMW X3 M Sport Pkg
1990 911 Cabrio triple black
2006 Mini Cooper S Checkmate - GONE
1987 Corvette - 18 yrs Gone,,, sniff sniff -
ish is offline   Reply With Quote
Old 08-21-2005, 07:48 PM   #4 (permalink)
RoverChic's Avatar
It sounds like the ABS Sensors (one of them) is kicking in prematurely. Which is usually indicitive of a bad/dirty sensor..and they are not cheap! However try to push them back in (clean them too with a steel wool pad), flush the brake system with Dot4, and see if that solves it..Donuts to Dollars it is one of the front sensors.
2001 D2 CDL
Old 08-22-2005, 05:58 PM   #5 (permalink)
I cleaned the ABS sensors on my son's car Sun morn before he took off back to Kansas City. They seemed tight and OK. I noticed that the springs between the pads on both sides were broken and replace them with some generic springs from hardware store. I also bled the four wheels and checked pressures. He called when he got back and said "NO light !!" but like I mentioned, it only happens sporatically. When you only have a couple of hours to get everything corrected, you can't dig too deep !!! With six other cars to maintain, I'm sometimes pressed for time to get ALL jobs accomplished... I also have a real job !! Cars and racing are my only time consuming HOBBY !!!
PFZ
Old 08-22-2005, 08:11 PM   #6 (permalink)
Mod. --- I'm watching you
darkknight1999's Avatar
I would think the heat shield on the exhaust is broken. Just weld it back up or cut it off and wrap the pipe or cat in heat tape.
-John
Some of my favorite quotes:
"what you do in life, echo's in eternity..."
"death smiles at us all... all a man can do is smile back..."
1999 Discovery II SE-7
darkknight1999 is offline   Reply With Quote
