Old 11-20-2005, 09:52 PM   #1 (permalink)
Joe Beierly
oberdahill's Avatar
Default ABS Sensors dirty
I, like many others, have the ABS light lit. I pulled the sensors the other day for cleaning and noticed that there was grease at the bottom of the sensor (and up to about 1.5 inches of the shaft). It didn't seem right to me that there would be grease in the plug. Is this normal? I wiped the grease off, used steel wool to clean the element and replaced it. I'm hesitant to buy new sensors if something else is wrong. ABS light still lit and I'm going to get an OBD computer reader at Autozone next week when I get to Norfolk.
Joe
96 D1 SE7
95 Volvo 850 Turbo
98 Chevy S-10
Pearl City, Hawaii
oberdahill is offline   Reply With Quote
Old 11-21-2005, 07:34 AM   #2 (permalink)
Joe,
A couple of thoughts, one there shouldn't be any grease for sure.
Old brake fluid can cause the ABS light to come on, how long has it been since you flushed the system?
Don't buy a scanner thinking youcan rad and clear the brake codes cause they won't. You need a special scanner usually only mechanic and the dealers can read these codes.
Cleaning the grease, as you, may fix the problem but the light will not go off by itself.
Good luck,
Nike J.
Old 11-21-2005, 07:52 AM   #3 (permalink)
Joe Beierly
oberdahill's Avatar
I have the check engine light too and that's why I may pick up the code reader. I'm on travel on the continent until next month and I plan on doing a complete power flush of the brake system/fluid when I get back. Once I pull the codes and figure if I can fix them myself, then I'll go to the dealer to have them cleared.
Joe
96 D1 SE7
95 Volvo 850 Turbo
98 Chevy S-10
Pearl City, Hawaii
Old 11-21-2005, 08:49 AM   #4 (permalink)
Polish and proud of it.
TsiArt's Avatar
I know that in Disco II there should be grease on it . The reason is that it gose inside the wheel bering hub . And it's more of like a magnetic pic up , so grease or no grease it will work . But you need grease for the wheel baring .
I know that cause I changed mine couple weeks ago .
I'm a Proud owner of a vehicle that has a turning Radius of 747
Check out our Frappr!
Myspace ? It dose not mather who votes, only matters who counts the votes _ Krushchew
TsiArt is offline   Reply With Quote
Old 11-21-2005, 09:40 AM   #5 (permalink)
I stand corrected.
Mike J.
Old 11-21-2005, 12:04 PM   #6 (permalink)
grease keeps water out and rust.
kinda of natural seal.
you can clean up and push in all the sensors and then reset the monitor test drive again to see if any codes exist.
and fix the ABS lite first and then clear the monitors and test drive.
More then likely the ABS lite set rough road code. IT shuts off the misfire.
The number is 1317 I believe.
Old 11-21-2005, 09:38 PM   #7 (permalink)
Joe Beierly
oberdahill's Avatar
beezel,
How do you reset the monitor? Is it something I can do easily or dealership item?
Joe
96 D1 SE7
95 Volvo 850 Turbo
98 Chevy S-10
Pearl City, Hawaii
Old 11-22-2005, 10:07 AM   #8 (permalink)
you can always try the disconnect the battery trick. Works pretty good most of the time.
but whomever you got the codes from you should be able to reset it as well.
just remember you got to drive it to prove out the system.
