Old 07-28-2006, 06:32 PM   #1 (permalink)
Default Ac Comes And Goes
Hey all I have a 95 d-1 The air condtioner will blow cold a$$ air on the highest setting and when you turn it down to 2 feels only luke warm Also when your on freeway stays cool in traffic will blow semi cold air Had it checked and there were no leaks and fluid is good .I wrapped pipes in pipe insulation and it melted LOL Any other suggestions
Thanks Eric
Gentrysrover95D is offline   Reply With Quote
Old 07-28-2006, 07:12 PM   #2 (permalink)
I would suggest you check and make sure all your fans are working, and there is no blockage in front of the radiator cause a lack of air flow to cool the condensor.
Old 07-28-2006, 07:13 PM   #3 (permalink)
Thanks for input Disco mike.. I was thinking of cleaning it out tomorrow Its not overheating so fans work just a odd thing i guess
Old 07-29-2006, 11:45 AM   #4 (permalink)
pavel's Avatar
When you turn down the fan to '2', does the compressor clutch disengage?
Old 07-29-2006, 05:53 PM   #5 (permalink)
No It doesnt disengage Think I am losing it ... I guess I am not use to the size of vehicle and time it takes to cool down In vermont we only run it 30 days a year Ill keep ya posted if it acts up for real LOL
Thanks Eric
