Old 07-29-2006, 11:55 AM   #1 (permalink)
jimbob
Default AC Recharge port
Where is the recharge port on a 95 Discovery? The ac is not working and I think I'll try a recharge kit to see if it might be a cheap solution for the balance of the summer.
Any thoughts on this. Tried the search function but could not find the location for the recharge port.
thanks
jimbob4207 is offline   Reply With Quote
Old 07-29-2006, 12:16 PM   #2 (permalink)
Don't waste your money one a recharge kit till you have verified you have a leak and where and what sort of a repair is needed. Does it work at all, does the compressor come on, is the low pressure line from the compressor cold when the compressor is on?????
Old 07-29-2006, 12:30 PM   #3 (permalink)
jimbob
Thanks for the idea. I'll check it
Old 07-29-2006, 01:20 PM   #4 (permalink)
Also make sure your electric cooling fans are working.
