Old 01-03-2006, 12:19 PM   #1 (permalink)
LANDY96's Avatar
Default Acceleration surge when cold only.
When I am starting out in the morning, and the engine is cold, I have some light surging. What is this all about. It almost feels like the clutch is slipping. I have bosch 4platinums in this. Could this be carbon build up from first start. As soon as the engine warms up in about 5 min of driving time. She smooths out all across the range. I have about 20k miles on these plugs. I know most of you don't like these plugs, but learned this after I bought them. Anyway no real problems. Thanks!
Eric The Red
93 Range Rover Classic
96 DISCO SE7 5-SPEED SOLD
96 DISCO SD 5-SPEED
-ARB Bumper
-OME 2" Lift
-2" spacers
-Safari snorkel
-15" steelies
Old 01-03-2006, 03:46 PM   #2 (permalink)
Don't knock the plugs, I run them and have lots of friends that use them with good results.
You could have a temp sensor failing, a fuel pressure problem or it could be ready for a good maintance service. How many miles on the truck? Have you changed out the plug wires, O2 sensors, cap and rotor, fuel filter???
Just some thoughts.
Mike J.
Old 01-03-2006, 06:17 PM   #3 (permalink)
Elephantitis penisitis
When was the last time you ran a good fuel injector cleaner?
Old 01-03-2006, 06:57 PM   #4 (permalink)
check the fuel pressure. if should read forty psi. turn it off and watch for it to stay the same. It shouldnt drop no more then maybe five in an old vehicle. if it drops fast then you have a problem. clamp off the return hose and check to see if it still drops. if it doesnt then its a regulator. if it does then its an injector or a pump. of course you need to test at the pump to verify that.
Old 01-04-2006, 09:16 AM   #5 (permalink)
LANDY96's Avatar
Well, guys, fuel pressure is good, filters have been changed recently, the truck has a gems system(no cap and rotor). I probably need to change the wires. And run some fuel cleaner, (what a dumba$$, I should have done this ) Thanks!!
Eric The Red
96 DISCO SD 5-SPEED
-ARB Bumper
-OME 2" Lift
-2" spacers
-Safari snorkel
-15" steelies
Old 01-04-2006, 10:38 AM   #6 (permalink)
Try to get ahold of some B&G 44K fuel injector cleaner. If you can't locate some, PM DiscoMike and he can tell you where to get some.
Old 01-04-2006, 09:52 PM   #7 (permalink)
Do you have an intake leak.
Its possible that the intake are leaking and its causing a vacuum leak.
Heres an idea take a can of carbureator cleaner and spray the intake gaskets.
If there is a leak the surging will go away for a moment as the vacuum picks up the carbureator cleaner.
If you have a scanner you could check long and short fuel trims.
