Old 10-04-2005, 09:09 PM   #1 (permalink)
Joe Beierly
oberdahill's Avatar
Default Anti-Lock light illuminated
The Anti-Lock light is lit on the dash. I pulled the 30 amp fuse from the engine compartment, still lit. Pulled the 5 amp and 10 amp fuses from the sockets and the light remains lit. Other than taking it to the dealer to have the codes read, is there a way to diagnose this problem or shut the light off? Not sure if it's the modulator (big bucks), brake booster, dirty ABS sensors or the system needs bleeding.
Joe
96 D1 SE7
95 Volvo 850 Turbo
98 Chevy S-10
Pearl City, Hawaii
oberdahill is offline   Reply With Quote
Old 10-06-2005, 01:18 AM   #2 (permalink)
No relation to Felix The Cat
FelixLockhart's Avatar
I believe there's a fourth fuse for the ABS system. If not, you could always unplug the indicator light under the dash
FelixLockhart is offline   Reply With Quote
Old 10-07-2005, 03:41 AM   #3 (permalink)
Joe Beierly
oberdahill's Avatar
Do you know where it's located? The owners manual only refers to the three that I pulled and reseated.
Joe
96 D1 SE7
95 Volvo 850 Turbo
98 Chevy S-10
Pearl City, Hawaii
Old 10-07-2005, 04:38 AM   #4 (permalink)
It seems I was mistaken, there are only three. The fourth fuse I pulled at the time was for the headlight sprayers, which have been broken since I got my truck (I finally removed the hosing for them last week, yay!)
Try pulling all the fuses with the truck off, then reset the computer and see if you get the light still. I have a '95, I'm not sure if they changed the system much between our model years. Good luck, though
Old 10-07-2005, 06:47 AM   #5 (permalink)
Joe Beierly
oberdahill's Avatar
Thanks. I'll bleed the brakes and probably unplug the light.
Joe
96 D1 SE7
95 Volvo 850 Turbo
98 Chevy S-10
Pearl City, Hawaii
Old 10-10-2005, 12:28 AM   #6 (permalink)
prob a stupid question but why would bleeding the breaks have to do with the ABS sensor/light...im kinda fuzzy on how that fits togther...
rov'n is offline   Reply With Quote
Old 10-10-2005, 03:32 AM   #7 (permalink)
Joe Beierly
oberdahill's Avatar
Bleeding the brakes was one of the "recommendations" I read before replacing expensive parts like the modualtor, ECU or sensors. The PO had the pads replaced and the pedal feels a little soft so there might be some air in the lines. Don't recall where I read it and don't know if the light is related. It's one way to begin the process of elimination. Next will be to clean the sensors and check the connections.
Joe
96 D1 SE7
95 Volvo 850 Turbo
98 Chevy S-10
Pearl City, Hawaii
Old 10-13-2005, 10:47 AM   #8 (permalink)
1 check all fuses
2 check all connections
3 try cleaning the abs sensors
4 replace the brake light switch at the peddle
5 still not working? now you are in the same shit as the rest of us
6 spend money getting the fault diagnosed
7 change the sensor the diagnoses says is at fault
Chances are its one of the front sensors but change the brake switch first
Best of luck
Sean
4x4disco is offline   Reply With Quote
Old 10-13-2005, 11:41 AM   #9 (permalink)
Joe Beierly
oberdahill's Avatar
I'm almost at number 5 already. Glad I don't drink, getting it all worked out sure could drive someone in that direction. I'm trying to post some pics from the fest last week. They serve beer by the liter and carry them by the loadful. Plenty of German folks having a great time.
Joe
96 D1 SE7
95 Volvo 850 Turbo
98 Chevy S-10
Pearl City, Hawaii
Old 10-13-2005, 02:15 PM   #10 (permalink)
For what it's worth, there was a recall on my ABS system on my '03 Disco. Not sure of the extent of the recall, but I remember them saying it involved several model years....
bernardmann is offline   Reply With Quote
Old 10-13-2005, 03:09 PM   #11 (permalink)
Discrover's Avatar
I have replaced and cleaned sensors to get the ABS light to go off...than after the $$$ and time doing so only to have the light come back on in a couple weeks . The ABS light in my opinion is like a revolvin door on D1's.
I am very anal about dash lights, but one thing I have learned about my D1 is keeping the dash lights off is a full time daily job.
Now I have just finally grown accustomed to all the Christmas looking lights on....my wifes car on the other hand that is a Nissan if a light comes on we both look at each other and say utt oh....lmao
My D1 is a 94 - 185,000 miles
Her Maxima - 95 - 220,000 miles
Bought both new around the same time.
Discrover
myrover.net
RAVphotography | My Car Domain Page
Discrover is offline   Reply With Quote
Old 10-13-2005, 08:08 PM   #12 (permalink)
Joe Beierly
oberdahill's Avatar
I hear you loud and clear on dash lights, they bug me when lit. I plan on doing all I can without becoming obsessive about it. The pedal is spongy so I'll bleed the lines and follow all the recommendations with cleaning. Other than that, I get used to staring at the light on the dash. The "revolving door" analogy hit the nail on the head.
Joe
96 D1 SE7
95 Volvo 850 Turbo
98 Chevy S-10
Pearl City, Hawaii
Old 10-17-2005, 02:04 PM   #13 (permalink)
I unplugged My ABS ECU and gave it the finger with some words to follow.
Why is it the lights you want to burn out never do and the hardest most expensive ones burnout like every other day.
Yeah Revolving Door is right. If it doesn't burn out soon i'm going to pull the cluster and remove the bulb.
I refuse to tip toe through Life only to arrive safely at Death
Rocks, Sand, Mud, Water whatever I just want to leave the pavement
Its your Life, LIVE it ENJOY it!
DiscoPilot is offline   Reply With Quote
