So .. I go out to drive to work the other morning, and unlock the door (with the key as it seems my remote has died - a number of days prior)
I try to start her up - and all I get is relays clicking. The starter doesn't turn. I notice that there is an LED flashing on the stereo. From this I am guessing that for what ever reason the alarm system has immobilised the vehicle (1994 NAS series 1 Disco) How the do I deactivate the immobiliser??
Black '02 Discover SII, Auto. ![]() Black '87 Suzuki Samurai, rock crawler :Black '94 Discovery SI V8i, 5 spd (Currently DOA) --## If you have enough time to do something over again, you had enough time to do it right the first time. ##-- |
Joe Beierly
Same thing happened to my Disco. Turns out the security ECU has gone bad and the choices were to (a) have it repaired by the local dealership or (b) order a used one online and replace. The dealer said to lock/unlock the driver door until the LED in the dash went out, then the starter will engage. That's only good enough to get to the dealer ship. Ended up programming one remote so at least I can drive. The replacement ECU should be here in a couple of days but I don't know if I have to re-program the remote. $390 USD diagnostic and programming and an additional $390 for repair. I got a used unit for $93 USD shipped. Pains the wallet getting it done.
Joe 96 D1 SE7 95 Volvo 850 Turbo 98 Chevy S-10 Pearl City, Hawaii |
#3 (permalink) | |
Found this article - not sure if it applies to a 1994 though but it sure sounds likely
Mentions pulling the immobiliser "spider" apart and resoldering joints. http://www.lrenthusiastforum.com/ubb...b=5&o=0&fpart= Quote:
Before you go nutz spending tons of money...
take something flat and open up the key fob (sp?), your remote and replace the battery. If that does not fix your problem... well... at least you only spend $3.00.
That is not a leak! That is undercarriage rust inhibitor. 98 Discovery |
Artist
I had a 94 Audi S4 and had a similar thing happen fixing it wasn't cheap so I found a work around that ws a pain in the ass ,b ut it was free...
1999 Disco II 2002 Golf GLS TDI shut up 40+ MPG
Well - replaced the batteries in the fob - now it works like a champ.
Same problem with the vehicle though. When I attempt to start her up, everything seems like it works ... except for the starter motor. I can hear the solenoid slide. The anti-theft LED on the mid left side of the stereo still flashes though. I would have thought it should have gone out. It flashes when trying to crank the engine, not when on accessory, and flashes when the key is inserted and not turned. Do I have the wrong idea that this is the alarm immobilising the starter/engine? I cannot find any info for resetting this. BTW - this is a Disco with the ONE BUTTON system
'94 and '95 have a much simpler immobilizer system. You can jumper 2 wires at the ECU and it will always start. Central locking all goes through the ECU, though, and if it pukes, your back to manual locks. There's a 6-pin plug on the alarm ECU. Pins 1 and 2 are black/orange. Pull them out of the plug and hook them together. All operation will be normal except for the lack of immobilization.
Joe Beierly
frickjp,
'94 and '95 have a much simpler immobilizer system. You can jumper 2 wires at the ECU and it will always start. Central locking all goes through the ECU, though, and if it pukes, your back to manual locks. There's a 6-pin plug on the alarm ECU. Pins 1 and 2 are black/orange. Pull them out of the plug and hook them together. All operation will be normal except for the lack of immobilization. 10-08-2005 07:05 PM Is is the same for a 96? I'm having the same problem and the dealership said it was the ECU gone bad and the antenna. If I could jump it to work around the deactivated starter, it would be great.
#10 (permalink) |
Joe Beierly
frickjp,
I thought that was the case. I'm dropping it off tomorrow to have the security ECU replaced and have another remote (clicker) added. I wish there was a way I could bypass the blasted thing.
