Hi,
Sorry to bother you at this time of the evening, however I am just about to replace my rubber dougnut that joins the rear propshaft to the diff, however the parts will not arrive until friday and the rubber doughnut on my Disco 1 has just started to disintegrate. It is obviously out of balance and the vibration and sound is getting worse, I dont want to causer any long term damage and was wondering if I could remove the rear prop shaft and drive only a short distance as a very temporary measure until my bits arrive ? if you have any input please rsvp, My best regards, John. PS : I am constantly amazed at the sheer strength and determination of these excellent vehicles to continue to work even when the parts start to catastrophically fail !! ![]() |
4x4 Adventure Gear
You can remove the rear DS put you will have to engage the center diff lock (in High obviously) or just leave it unlocked and apply the emergency brake.
You'll get better mileage and the truck will feel like a car. You are going to replace it with another rotoflex? Why not convert it to a u-joint type DS? You can do the conversion for around $150-180. Just a thought.
John C 1996 DI - 3" AG lift 1995 DI - Scorpion Racing Extreme Kit 1991 RR - parting out (few parts left) 1990 Kawasaki KL650B Tengai 1989 Kawasaki KLR650 |
thanks John,
I am going to do this this evening, I have some parts arriving from paddock spares in England, but If this happens again I will for sure convert to a solid link, PS : same name John C Once again thanks for the quick reply! |
4x4 Adventure Gear
Actually my name is Giampaulo Cinquegrana (John Paul in english) but most people find it easy to call me John C.
Good luck,
John C that's an interesting idea - take off the rear drive shaft and apply the emergency brake. But I'm thinking, in that case won't the centre diff be transfering all the torque to the front and if you drive a good distance could it not really heat up? Of course if you lock up the diff instead, then the 'bevel' gears wont be turning which would put much less stress on the unit... is my logic here OK?
Hey my son just had another idea/question - if you use the emergency brake route, wont the front drive shaft turn much faster (twice as fast?) and therefore wont you effectively get a different gear ratio sent to the front axle? |
#7 (permalink) | |
Series Moderator
#8 (permalink) | |
Series Moderator
If you got the right bits sent ill be amazed in 13 years of ordering with paddocks I have never recieved a full correct order!!! |
#9 (permalink) | |
4x4 Adventure Gear
#10 (permalink) | |
The handbrake is a very bad idea. When you apply the handbrake, all the power goes forward through that very tiny centre differential. There are no bearings in that unit, and you'll destroy it in short order. When you pull either shaft, you can lock the centre diff and drive it 'till your heart's content without hurting anything. They handle a bit strange with only front drive, so be careful. If you pull the rear shaft, you either need to remove the handbrake drum or put the nuts back on that retain the driveshaft. You'll need some washers, as the studs are not threaded all the way in. There is one screw that holds the drum in place, but it is not intended to hold it while driving without the shaft in place. One more detail often overlooked. When you install the new Rotoflex, there are arrows on the outside perimeter. These arrows will point to the flange ears. There's only one proper way to install it. Install it wrong, and it will not last. |
#11 (permalink) |
4x4 Adventure Gear
Handbrake will work for very short distances (moving it around in your driveway, etc).
#12 (permalink) | |
At any rate, the initial question was if the truck could be run with one shaft. WTF des the handbrake have to do with this question? Try your handbrake routine, and you're not even going to make it a mile before you now need a rotoflex AND a transfer box. |
#13 (permalink) |
looks like I opened a can of worms on this subject.
Ok so here is what I did. I did remove the rear prop shaft, I put the hand brake on and did drive a short distance, 20kms in total at slow speeds. No problems to report, except I found out that my diff lock is not functioning !! No surprise there, so now I will post a new topic asking for the best ways to get the difflock de-siezed and functioning, and I will also do a new post on British parts suppliers............................ Thanks for all of your responses on this one, stay tuned. John. |
