Old 03-21-2005, 11:27 PM   #1 (permalink)
Default Anyone remove the side trim for a Disco I?
I was wondering if anyone has ever removed the side trim off a disco I? Did it look any good? Do you have any pictures? What do you think about removing the trim?
RickyRover is offline   Reply With Quote
Old 03-22-2005, 01:33 AM   #2 (permalink)
Super Moderator
Disco's Avatar
Are you referring to the plastic trim running from the front fender to the rear in the centre of the vehicle? If so, then I guess it's a matter of taste. On my 91, I actually put the trim on as the disco looked a bit naked.
Old 03-22-2005, 09:12 AM   #3 (permalink)
I also bought mine for my Disco ll from www.roverconnection.com when I saw Disco Mike's Disco ll with them installed.They have two versions, a black with a chromed strip in the center and an all-black one.I chose the blacked-out ones, still waiting for the weather to get a bit warmer around here in order to install them.In my opinion you should leave them installed, as it is also a "ding" protection for your truck.
Carlos
Carlos is offline   Reply With Quote
Old 03-26-2005, 09:16 PM   #4 (permalink)
The factory trim on the Disco I's is just on with double side tape. If you remove it you will notice square holes under the trim for installing factory full trim that also cover the wheel wells like on the II's. I wouldn't remove it unless you plan on filling in the holes or installing trim upgrade.
totallymann is offline   Reply With Quote
