Old 08-10-2007, 07:59 PM   #1 (permalink)
Default Auto transmission shifting question
Not being an experienced Land Rover owner I need to know if this is normal. When coasting at 35-40 mph the transmission can't decide what gear it wants. I am assuming 2nd and 3rd gear. It just goes back and forth between gears until I press on the gas or it drops down to under 35 and it will go to 2nd. Just did a fluid and filter change, it also did it before.
Any ideas on what a solution might be?
Greg
1997 disco 150,000 mi
tgmiller77 is offline   Reply With Quote
Old 08-10-2007, 08:02 PM   #2 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
This might be what your talking about.
Engine Speed Fluctuation at Moderate Speed Closed Throttle
AFFECTED VEHICLE RANGE:
DISCOVERY (LJ) 1997 MY Advanced EVAPS Equipped
VIN: up to VA727076 Automatic
up to VA726789 Manual
up to VA558898 Manual and Automatic
SITUATION:
IDLE FLUCTUATES DURING MODERATE SPEED CLOSED THROTTLE OPERATION There have been reports of engine flare or surge when the vehicle is decelerating. The engine speed may fluctuate between 1200 and 1600 rpm (up to 400 rpm total fluctuation) when the throttle is closed and the vehicle speed is between 35 and 50 mph (56-80 kph.). This may occur in GEMS equipped, Advanced EVAPS vehicles in the above VIN ranges.
RESOLUTION:
REPLACE PROM
Upon customer complaint only, install a new PROM set which has been developed to eliminate the problem. Replace the PROM set using established Operation Pride procedures. (TIB 19/08/96/US)
PARTS INFORMATION:
PRM9640 PROM (Automatic)
PRM9641 PROM (Manual)
LRNASTATK Anti-Static Mat
REPAIR PROCEDURE:
REPLACE PROM
NOTE: Make sure to complete the DPR and FAX to LRNA.
Use procedures outlined in earlier phases of Operation Pride to replace PROM set.
(TIB 19/08/96/US)
Following installation of the PROM set, start and warm up the vehicle from full cold to hot at idle, in Drive with the Park Brake applied. This will adapt the engine management IACV system and minimize any noticeable changes to the customer upon return of the vehicle.
Michael Polensek For Pres 2008!!!!
1997 Disco 1
2000 Disco 2
1989 RR(gone but not forgotten )
Miami Valley Land Rover Society
www.mvlrs.com
ON WISCONSIN
Badger1 is online now   Reply With Quote
Old 08-10-2007, 08:03 PM   #3 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Just wanted to add this was found on Dweb and pasted here.
1997 Disco 1
2000 Disco 2
www.mvlrs.com
ON WISCONSIN
Old 08-10-2007, 08:12 PM   #4 (permalink)
Greg, you may also be looking at a shift cable adjustment. Unlike D2's D1's shift based on throttle pressure that is transfered to the tranny by an adjustable cable, yours might be out of adjustment.
Old 08-10-2007, 08:52 PM   #5 (permalink)
I am leaning toward the shift cable. Because it does it between 3rd and 4th tooand at very exact speeds. Should I take it to a transmission shop to get them to make the adjustment?
It could also be what Badger1 suggests and it is just showing up in the tranny. The rpm's do jump when it is acting up. Was this a recall or just a service bulletin? How do you diagnose? It quits with just slight pressure on the gas pedal.
Thanks for the help!
Old 08-11-2007, 05:37 AM   #6 (permalink)
Elemental's Avatar
If you are even slightly handly with 2 9/16---15mm wrenches you can do it.
http://www.discoweb.org/forums/showt...kickdown+cable
When I was done with her, her bed needed Shamwow sheets!
Old 08-11-2007, 06:24 AM   #7 (permalink)
I will give it a shot this morning. I guess, from what I understand, I just need to take the slack out of the cable
Old 08-11-2007, 06:25 AM   #8 (permalink)
Looks like a TSB.
Old 08-11-2007, 11:13 AM   #9 (permalink)
It was the shift cable!!! Took out the slack per the diagram on the link and it cleared it right up. Thanks
Old 08-11-2007, 01:13 PM   #10 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Good to hear you got it sorted.
1997 Disco 1
2000 Disco 2
www.mvlrs.com
ON WISCONSIN
Old 08-14-2007, 07:21 PM   #11 (permalink)
Well, I spoke too soon.
Still having the shifting issue. It is better when the engine is warming up, but at normal temps it starts back up with the crazy shifting. If the adjustment of about 1mm is correct could it be something else like the cable binding up? The throttle cable was doing that and causing a high idle, could that be a possibility? Should I spray some Seafoam(Deep Creep) into the Throttle pressure cable to give it some lube. I have read posts that this shifting is not good for the transmission and should be fixed or you will kill the transmission.
Greg
Old 08-15-2007, 09:51 AM   #12 (permalink)
I took it to a local transmission shop today to see if they could get the cable right. They took a look at it, saw that it was snapping back as it should. They drove it and said it was probably the torque converter going into "permature lockup". They said there was no way of knowing until they pulled the transmission to test/inspect.
Should this throw a code? Also, the diagnostic plug is hanging out from the bottom of the dash. Should that be plugged into something or is it o.k. to leave it.
Please help before my wallet gets raped.
Greg
Old 08-15-2007, 10:04 AM   #13 (permalink)
The tranny on a D1 is mechanical, not electronically control so there are no codes.
The OBD2 plug should be secured up in it's spot but effect anything if not other then being in the way.
Old 08-15-2007, 11:11 AM   #14 (permalink)
So does this sound like the torque converter going out? If so, I saw one on the internet for $150 what should the labor run at an independant transmission shop?
Old 08-15-2007, 11:18 AM   #15 (permalink)
Big $$$'s.
Before you try and throw parts and labor at it how about a good tranny additive like Lucas to see if it will free up the shifting and locking process, $10 can't hurt in the whole sceme of things.
