Old 11-17-2005, 11:48 AM   #1 (permalink)
Herbie85's Avatar
Default Automatic Door Lock Problems
When I push down the driver side door lock all the locks lock as they are supposed to, but when I shut the door they all unlock. Also if locking from the passenger side, if I lock the door and shut it, it re-opens as well. Any ideas as to what this could be? Possible re-soldering of ECU unit?
Herbie85 is offline   Reply With Quote
Old 11-17-2005, 12:12 PM   #2 (permalink)
No relation to Felix The Cat
FelixLockhart's Avatar
This is a feature, not a glitch, to prevent you from locking your keys in the truck. The doors can only be locked from the outside by using the key, or the remote transmitter.
Felix J. Lockhart
1995 Land Rover Discovery (Series 1)
FelixLockhart is offline   Reply With Quote
Old 11-17-2005, 12:12 PM   #3 (permalink)
It is designed that way. To keep you from locking your keys in by accident..
Unruely is offline   Reply With Quote
Old 11-17-2005, 12:12 PM   #4 (permalink)
I tried mine it won't lock and stay locked unless all doors are shut. they are supposed to do that
I refuse to tip toe through Life only to arrive safely at Death
Rocks, Sand, Mud, Water whatever I just want to leave the pavement
Its your Life, LIVE it ENJOY it!
DiscoPilot is offline   Reply With Quote
Old 11-18-2005, 03:33 PM   #5 (permalink)
if you must, open the back door and press down the drivers button.
close the back door, it will then stay locked.
probably with your keys in.
Sean
4x4disco is offline   Reply With Quote
