Old 08-20-2008, 10:13 AM   #1 (permalink)
H-vegasdisco's Avatar
Default Backfiring
My truck started backfiring throught the air intake on sat. and I thought it could be a maf problem so I installed a another maf that works yesterday and it still is backfiring. I am leaning toward the tps but does anybody have any insight? Oh and I erased the codes after putting the new maf on so I don't have those either. Also it won't really rev over 1750 rpms either.
1997 Discovery 5spd LSE
1997 Volvo 850
H-vegasdisco is offline   Reply With Quote
Old 08-20-2008, 10:21 AM   #2 (permalink)
Elemental's Avatar
Gasoline Otto Engine No start/Misfire Diag Principles.
Backfiring is almsot always I timing issue. Shotgunning sensors will not cure that.
However, the Crank Sensor does come loose, and will affect timing.
When I was done with her, her bed needed Shamwow sheets!
Old 08-20-2008, 10:50 AM   #3 (permalink)
TerryS's Avatar
The airflow sensor would not likely be the cause of backfiring back through the intake, but it can quickly be ruined by it.
Intake backfiring can be a result of timing, or crossfiring through bad wires, but more frequently it results from a worn cam, or other valvetrain wear, such as a sloppy chain or worn chainwheels. Exhaust backfiring is caused by timing, crossfiring, carbon buildup or excessive fueling. How many miles on your truck
Old 08-20-2008, 11:21 AM   #4 (permalink)
Elemental's Avatar
The tests I outlined will point out why you are backfiring...
But, testing involves actually doing something. Its easier for this board to be spoonfeed the answer.
Old 08-20-2008, 11:21 AM   #5 (permalink)
the engine has around 108k miles on it
1997 Volvo 850
Old 08-20-2008, 11:29 AM   #6 (permalink)
Elemental's Avatar
Start testing. I gave you enough information to start diagnosis.
Old 08-20-2008, 05:39 PM   #7 (permalink)
It was the dang crankshaft position sensor.
1997 Volvo 850
