Old 05-20-2008, 07:38 PM   #1 (permalink)
Default base idle adjustment?? stalling, idle issue
1997 Discovery 4.0
I'm experiencing some idle/stalling issues. Car will run with gas pedal depressed but will stall out when at closed throttle. Iacv stepper motor, fuel pump have been replaced. I have constant fuel pressure (30-35) at the rail with no bleed off when engine is cut off. Intake, throttle body have been thoroughly clean.
I'm assuming my base idle might need to be adjusted. It runs great when gas pedal is floored...no hesitation at all. SO is the idle adjust right on top of the plenum/intake? Right now, I have the throttle cable tighten a tad bit, idles at 1000rpm just to keep it from stalling.
bothfeetin is offline   Reply With Quote
Stalling issue - random lsawicki Range Rover Classic 11 05-15-2008 02:55 PM
Idle Control Valve - idle problems; get to know it glenncof Range Rover Classic 2 02-24-2008 01:57 PM
97 Disco low idle issue... timkel74@msn.com Discovery Series I 8 02-12-2008 06:39 PM
correct procedure for setting base idle? deadboy1977 Range Rover Classic 0 12-11-2007 01:11 PM
Advice on setting base idle norville Range Rover Classic 6 02-23-2007 01:22 PM
