Old 04-11-2008, 08:25 PM   #1 (permalink)
Default Battery Ground Question 1994 Disco I
I am just fixing up this 1994 Disco I, I got, and due to sluggish starting with brand new battery when the truck is warm, I started thinking about the battery negative (ground) cable. I traced it to where it is connected to the frame of the truck, and that is all I found. Does the engine have a ground strap to the engine or body somewhere? If so, where would I look. If I were going to add one, what would be the advisible point on the engine to attach one? This may be my problem, or may not. But a lot of problems can be due to poor connections between the battery and the vehicle electrical systems. Since I only found an attachment to the frame, I am also wondering about a ground strap from frame to body? Or is this supposed to be accomplished thru the body bolts?
I could add two more negative "strapping" cables to the battery negative attachment point-where the battery negative cable is bolted to the frame, and one of these cables could go to the engine (somewhere) and another could go to the body. That would ensure a good return and full voltage at all times. Opinions?
Phototone is offline   Reply With Quote
Old 04-13-2008, 12:38 PM   #2 (permalink)
daniels disco
Hi., sounds like you are going to need a starter soon. I also havd a D-1 (94) and I had a similar problem. I checked fuses,wiring, ignition etc... and ended up getting the stock starter rebuilt. When you look at the starter, you will notice heat shields attached to the exhaust pipe., these shields are to keep the starter from expansion/contraction, but the starters will fail in time.
If you have a stock starter, (such as mine) I would advise you to pull it off and have a tech bench test it for you. good luck., it's a &*#(&#. dan
daniels disco is offline   Reply With Quote
Old 04-13-2008, 01:02 PM   #3 (permalink)
Well, before I go pulling a starter, I cleaned and refreshed the battery to frame, and starter/engine to frame ground strap connections, and will see if that will make a difference. They were fairly corroded. Haven't tested yet, as the truck is waiting on another part right now. (Non electrical).
Sluggish starter when engine warmed up 1994 Disco Phototone Discovery Series I 1 04-10-2008 06:12 PM
Wheels and Wheel Spacers Question - 18" Disco I jkcoda007 Discovery Series I 0 01-08-2006 09:54 AM
battery question 98RRover Range Rover P38, Mk III and Range Rover Sport 2 08-24-2005 12:17 PM
Dual Battery Set up question AdrianL Range Rover Classic 4 08-13-2005 06:24 PM
Battery question Hailsharky General Land Rover Discussion 13 06-08-2005 09:20 PM
