Old 12-18-2007, 04:23 PM   #1 (permalink)
Default Battery Light
In October of this year I had the battery in my 1998 Discovery I replaced with a new one.
Driving home this evening, the battery charging light sporadically went on and off.
No change in power or dimming of lights however the tachometer went crazy at the same time of the battery light flashing.
Any Ideas as to what might be the problem?
Thanks in advance for any words of wisdom.
1998 Discovery Series I
Quack98 is offline   Reply With Quote
Old 12-18-2007, 06:45 PM   #2 (permalink)
Go straight down to where you bought the battery and get a free battery/alternator load test, one of them is bad. If you want you can also go to most auto parts store where they will also do a free test.
Make sure that you clean and retighten you battery connections first.
under the hood light unit & battery..... daway Land Rover Parts and Vehicles Wanted 5 12-22-2006 06:15 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 04:50 AM
Battery Light kdkg Range Rover Classic 6 10-06-2005 06:05 AM
HELP! Battery light stays on, won't start, hesitation when jumped??? Roverranger Range Rover Classic 6 07-03-2005 06:23 PM
Battery icon light came on, 90 classic after changing plugs, etc...? ronrover Range Rover Classic 4 01-21-2005 07:34 AM
