Old 01-03-2008, 02:53 PM   #1 (permalink)
Default Best Plug?
Im sure this has been asked a 1000 times. Here is a 1001! What are the best plugs to run with Magnecor 8MM wirers? Im thinking either Champion Platinum or Bosch Platinum. Any thoughts or opions?
kennyday is offline   Reply With Quote
Old 01-03-2008, 03:06 PM   #2 (permalink)
Elemental's Avatar
Funny thing.... The enginners at Land Rover thought the same thing... So, they tested their engine against numerous plugs, and found the Copper $.99 Champion plugs to work best. So they used them. Gotta go with that, being that they likely know more then we do.
Bosch plats....
Old 01-03-2008, 03:30 PM   #3 (permalink)
Of course they don't sell that plug for their engines, only the $12 variety at the dealership.
Then to, the engine was built and ran on AC plugs for the first 20 years of use, and that too was well researched, so who is to say what plug really works best but the people who own and use all the different plugs that are currently on the market.
Old 01-03-2008, 03:34 PM   #4 (permalink)
Elemental's Avatar
If you coudl produce more power, better fuel economy and less emissions from a wiz bang spark plug design, why wouldn't they do it from the factory? Doesnt make sense does it?
Old 01-03-2008, 03:42 PM   #5 (permalink)
msggunny's Avatar
Gallery: 5
Just get what ever kind you want,
Unless you have done a lot to your engine, you wont notice anything anyways by running the super duper whiz bang neoplatinum-depletedurainium 56prong super gas mizer 50hp boosting plug.
Its your money..
77 SIII 88
97 D1 5 speed
91 D1 5 speed (the first, but gone )
When god gives you lemons, find a new god....
msggunny is offline   Reply With Quote
Old 01-03-2008, 04:30 PM   #6 (permalink)
Rebuilding Rover
ArmyRover's Avatar
What is the best plug?
Whatever makes you happy.
I run the 99 cent copper core champions with no ill effects
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 01-03-2008, 05:12 PM   #7 (permalink)
Elemental's Avatar
That isnt compeltely true. You could screw a bolt in the hole. It would fit, but it wouldnt work. Use the Champions like look just like the ones that came in from the factory. At best, these wizbang plugs performance will be equal, at worst, you could damage the engine.
I have personally seen a Bosch plat come part, fall into the combustion chamber and dent the piston(Interferring with the Air/Fuel sqirl) and chipping the valve.
THe wheel has already been invented. No need to improve it.
Old 01-04-2008, 07:21 AM   #8 (permalink)
antichrist's Avatar
I buy whatever is cheapest for mine, usually the autolite or champion.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1
95 D90
Transfer case drain plug..... Bonehead Discovery Series I 4 08-21-2006 10:21 PM
Spark Plug Wires-Testing RageRover Range Rover Classic 16 05-18-2006 05:36 AM
Stripped the spark plug hole... RageRover Range Rover Classic 2 02-15-2006 06:29 PM
spark plug #6 misfire mc30306 Range Rover P38, Mk III and Range Rover Sport 5 08-22-2005 04:32 AM
'99 DSII both front fog/driving light bulb plug melted Tnee Discovery Series I 3 11-24-2004 07:20 AM
