Old 09-22-2005, 04:44 PM   #1 (permalink)
Exclamation Board NEWB with Problem's
First off i would like to say hello all and that i jave been lurking for quite sometime.
I have had 98 disco for a little over a year now and love it. I'm used to cars with little issues. I think they are personality triats in a way. I own a performance automotive shop just south of Charlotte, NC USA.
I have all the factory manuals for the car however they don't really cover they stuff that owners and land rover mechanics would know.
First off, as of last week the center diff selector is stuck in high range. the diff will lock and unlock. I have pushed on it but not hard nor have i had time to get under the truck. I normally work out the transfer case once every couple weeks by doing the low range/high range locked/unlocked stuff in the woods just to keep it all working right. Suggestions? common?
Second I'm getting a check engine code P1317 which i believe to be an ignition system malfunction or misfire. The truck has new plugs and wires barely 5k miles old. The truck runs great. Common? Causes? suggestions?
I can and will figure out and fix these problems, however if anyone knows of common cause or has suggestion they'd be greatly appreciated as it can help me eliminate alot of things right out of the gate.
AWESOME BOARD GUYS!!!! GLAD TO BE HERE, CHEERS!
DiscoPilot is offline   Reply With Quote
Old 09-22-2005, 09:05 PM   #2 (permalink)
Elephantitis penisitis
Your truck doesn't leak enough to keep it lubricated! In all reality, the previous owner probably never used it much. Get under the truck and lubricate the linkage, then keep working it until it goes into low gear. I'm sure Terry S. and John C. will have more to add on this.
But welcome to the board. Pull up a sheep and pop open a cold one.
Old 09-23-2005, 04:27 AM   #3 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
If your not interested in the sheep thing make sure you bring a roll of duct tape!! Who likes it when they actually try to make conversation?
Anyway, welcome to the board.
Badger1 is online now   Reply With Quote
Old 09-23-2005, 05:30 AM   #4 (permalink)
Oh the truck leaks enough just not in the right spot. The power steering is lubricating the shit out of my steering components and the drive way.
And the rear main likes to remind me it leaks by nicely distributing about a qt every 2 weeks
Noted Duck tape in hand!
Necrophilia, crack open a cold one
I refuse to tip toe through Life only to arrive safely at Death
Rocks, Sand, Mud, Water whatever I just want to leave the pavement
Its your Life, LIVE it ENJOY it!
