Old 05-09-2006, 06:45 AM   #16 (permalink)
The Best 4X4XFar
300bhp/ton's Avatar
Originally Posted by Muddy Oval
One common problem on Rovers- especially Discos- is the rear shock tower is so close to the underside of the tub. One of the best ways to make a long travel suspension is to raise the tub to allow room for the upper shock mount to be moved farther up... then run a REALLY long shock. It allows huge drop but still allows it to stuff well. To do that requires a slight body lift or re-forming the rear floor of the tub. In some instances moving the body on the frame is a very good way to go. I don't think I'll be doing it on any of mine, but for other applications it works well.
I agree with the rear shock mounting although you can by relocation mounts which don't need any body modifications at all. Scorpion Racing offer 2 different ones and Devon 4x4 also offer swivel mounts.
But yeah I really don't like the 'gaps' you often get with body lifts.
The Best 4X4XFar
Old 05-09-2006, 06:49 AM   #17 (permalink)
The Best 4X4XFar
300bhp/ton's Avatar
Originally Posted by roverX
Interestingly enough, I and a few others, decided not to adjust the steering stops when we went to 265's. Reason being was that even though the tires rubbed at full turn, slight rubbing while going 1mph on the trail really is no big deal and can mean a world of difference on a narrow trail with tight turns. You just have to learn the new turning radius of your truck and not let the tires rub during street driving.
All you need to do is run better off set wheels.
When I put the 33's on mine they would rub at full lock and the turing circle was massivly reduced. This is not good for off roading or indeed parking, lol
This was using after market steel 8 spokes which stick out further than stock steel/alloy wheels. I know run 1" spacers also. This has allowed be to completly wind in the steering stops so it's the hub casing which limits the steering. The turing circle is awesom way better than a stock D90.
However I still want more so I'm getting some wheels made for me by a company called Matt Lee Engineering they make the Mach 5 steel wheels. The off set should make the wheels stick further out than the current 8 spokes with the spacer so it means I can ditch the spacers.
The Best 4X4XFar
Old 05-09-2006, 08:23 AM   #18 (permalink)
Otherwise known as STEVE
Running a lot off offset can cause premature bearing failures and break stuff- but on an offroad rig those things should be replaced more often and monitored closely anyway.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
