Old 09-26-2004, 11:15 AM   #1 (permalink)
Default Brake light problem
Have 1996 Dico II problem with brake lights not coming on when brake light depressed. I check all fuses - test OK. There are 2 plunger switches by the brake peddle ( large rectangular one, smaller round one ) which of these is for the break lights or are both? Help no manuals.
marcR is offline   Reply With Quote
Old 09-26-2004, 10:19 PM   #2 (permalink)
I think it is the larger plud, you should test both and see if you get a signal when the pedal is depressed.
Mike J
Old 09-29-2004, 09:55 AM   #3 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Default Push in all your connectors....
Howdy!
I had a nonworking left reverse light I had to work on. The filament was blown , replaced the bulb but I had also found the Molexpower connector had worked its way out. A good push , and the connector snapped back in place and all was working.
On eBay, there are plenty of folks selling the service manuals for the LandRovers for cheap,if you have a laptop or Windows computer.
Old 09-29-2004, 11:17 AM   #4 (permalink)
if you can get the truck out of park then the switch is ok if not its the rectangular (or bottom) switch.
rovertech is offline   Reply With Quote
