Old 09-03-2007, 04:22 PM   #1 (permalink)
Default Brake ?'s
I have a 97 Discovery 5 spd does not get driven on a daily basis brakes worked just fine until one weekend I got in to go for a trail ride and the break pedal felt fine when the car was not running but as soon as I started it the brake pedal went right to the floor and you have to pump the brakes to get them to work. The fluid level is fine check it before every drive and the level never goes down.
Is it the brake booster? Is this a common problem?
Any way to check the booster to make sure that is it before I go out and buy one?
Thank you for your help
Scott
Scott_97 is offline   Reply With Quote
Old 09-03-2007, 04:29 PM   #2 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Wink Happened to me....
Hi from Adam in NYC USA
Had that happened to me on the highway. I pressed for a hard stop and then the brake pedal went to the floor on my 96 D1 with ABS. When I had the brakes checked, one of the front brake pads had split in half after being worn down.
You now know what to do and what to look for. Dont underestimate the power transmitted to the brake pads for the ABS system. It is very powerful and I learned a lot about the robust power on some of the factory systems on a Rover. I just discovered a rear drive shaft that had its bolts holes severed after a rough winter.
Adam in NYC USA
PS if you are going to use it for off-road, why not upgrade to the premium metal/klevar pads and the slotted/drilled rotors for best stopping performance.
inert facts.
Old 09-06-2007, 05:43 PM   #3 (permalink)
Checked the brake pads and all of them are good any other suggestions?
Old 09-07-2007, 06:13 AM   #4 (permalink)
Sounds like your master cylinder is failing, what you described is the most common way they will react when failing, time to replace it.
Old 09-07-2007, 08:48 AM   #5 (permalink)
Thanks Mike I will check it out.
