Hi,
The break pedal will fight back and stutter when comming to a stop sometimes. then the abs light will go on and stay on. usually that will stop it from happening again till i turn off the car. Also the cruise control will not engage if that has anything to do with it. Any insights or comments would be helpful. Thanks in advance ![]() |
thats the abs activating. but its possible you have an issue with a sensor coming loose or a loose wheel bearing or shim.
basically tap the wheel speed sensors down with a small screwdriver very litely and to fix your cruise control check the hoses on the driverside near the brake booster and there is a three way tee, if the hoses are cracked then clip a bit of the hose to fit them on. if the abs light comes back on then lift the truck on a jack and check to make sure no play in the wheel bearings.
| Thread Tools | |
| Display Modes | |
| Detailing 101: Common Question and Answers, What and Where to buy stuff + Technique | David | General Land Rover Discussion | 52 | 08-23-2008 11:36 AM |
| I am back on island | BIRD | The Lounge | 5 | 02-08-2007 08:39 AM |
| [ALL] Detailing FAQ's + Technique | Disco | Tech & DIY | 0 | 01-08-2007 04:31 AM |
| Glad to be back | BlueLion | Discovery Series II | 6 | 07-19-2006 06:11 PM |
| Transmission clank normal between 30-70?? when you back off the gas then get back on? | amnesia622 | Discovery Series II | 15 | 03-06-2006 01:58 PM |
