Old 11-03-2005, 08:37 AM   #1 (permalink)
Green DISCO UNO
Default Breaks
Thanks I will bring this tip to the mechanic because he never work on a Disco before
Hello,
I have a Disco 1 and have been experiencing loss of brake friction that comes and goes slowly when I stop. The brakes will work, but I need to press down completely and it basically comes to a rolled stop. At that point, I start pumping the brakes which makes it stop a little better. It feels as if the brakes can go completely at any minute. Then it goes back to normal. It is not leaking break fluid. Anyone have this happen? If so, what is the cause and $$ to fix? thankk you
Eduardo is offline   Reply With Quote
Old 11-03-2005, 09:12 AM   #2 (permalink)
Rocky Mountain High
Funrover's Avatar
I had a similar problem on my RRC....It was the master cylinder for me...I don't remember the cost, but i remember it wasn't as bad as I thought!!
Old 11-03-2005, 09:47 AM   #3 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Start easy, try bleeding the lines. If it's not that simple(never is, is it) start looking at the more expensive items.
Badger1 is online now   Reply With Quote
Old 11-03-2005, 11:17 AM   #4 (permalink)
look for leaks in any line, or caliper.
also is the vehicle pulling. Many a times a stuck caliper that is leaking will pull.
Old 11-03-2005, 04:03 PM   #5 (permalink)
Default Brake Fade
Eduardo,
How long has it been since you flushed your brake fluid. If you fluid is burned, OLD, you will experience a soft and fade brake pedal while stopping.
It is cheap and quick to do a complete flush, try it and drive for a couple of days before you panic and need to pay a mechanic.
Mike J.
Old 11-03-2005, 08:40 PM   #6 (permalink)
Bogatyr's Avatar
Good suggestions here...certainly, brake fluid should be changed every two years...
It could be a master cylinder that's on it's way south...I've also seen similar symptoms with a flex line that's on it's way out...could also be air in the system, but if it doesn't happen all the time, prolly not.
Start with a simple bleed out...but start saving those pennies for a MC...I was perusing the RN catalog, didn't seem like it would be that expensive...
Bogatyr
Current Rover Fleet:
Old 11-04-2005, 08:37 AM   #7 (permalink)
My Bet is on the master cylinder... i would try flushing the system but I doubt it will rectify your issue. I'd start looking for best pricing i could find on master cylinders.. its not a difficult fix.
I refuse to tip toe through Life only to arrive safely at Death
Rocks, Sand, Mud, Water whatever I just want to leave the pavement
Its your Life, LIVE it ENJOY it!
DiscoPilot is offline   Reply With Quote
Old 11-07-2005, 09:17 AM   #8 (permalink)
Green DISCO UNO
Thanks allot great suggestions
