Old 02-28-2005, 11:48 AM   #1 (permalink)
Default breather valve on front/rear diff
Where is the breather valve on front/rear diff?? what am I looking for On my truckits a spring valve so On my disco I am lost.. thanks Eric
95 disco 3.9L
undefinedundefined
GentrysRover is offline   Reply With Quote
Old 02-28-2005, 01:20 PM   #2 (permalink)
TerryS's Avatar
It's not a valve, but simply a Banjo fitting to which a tube is attached. It's purpose is to prevent pressure and vaccuum from building when the gear oil heats and cools. It's located on the top of the axle casing to the left of the differential, about a foot.
Old 02-28-2005, 02:03 PM   #3 (permalink)
if you have time and ever take it off road or thru water, definately exted the breather lines up to the gas filler for the rear axle, and the front to the highest point in the engine bay.
2001 Discovery SE7 -- Sold Thank God!!! Toyota Only Baby.
JMan is offline   Reply With Quote
Old 02-28-2005, 03:41 PM   #4 (permalink)
TerryS's Avatar
I don't know about D2, but Defenders, and I know my son's D1 XD has tubes which run from the axle breathers to a high point.
If you're seeing evidence of oil slung from the center of your rear wheel hubs, outwards, that's a pretty good sign your breather fitting, or tubes, have become plugged. The steel fitting that goes through the banjo, into the axle casing has a tendency to become plugged with rust, from condensation. Clean the area around the fitting with a wire brush, and blow any dirt/ residue away, before unscrewing the fitting, to prevent crap from falling into the axle housing.
