Old 10-16-2006, 05:58 PM   #16 (permalink)
Rocky Mountain High
Funrover's Avatar
Originally Posted by p76rangie
Funrover, can you explain to me how extended bump stops add weight to the dropped wheel.
Ian
Not weight in the sense you are thinking.... When you have larger stops the axles has a limited uptravel.... once it hits it begins to force the other side down.... thus putting force/weight on the dropped wheel... not much.....but in many instances enough to get you over the rock!!!!!
