Old 09-01-2008, 06:50 PM   #1 (permalink)
I'll never forget the day we met
Horseshoe's Avatar
Default Caliper Brake Line Q
I broke one of my metal brake lines connected to my caliper this morning. I was wondering if these can replaced with flex hose for easier caliper removal and if they can not, do they sell the metal lines pre shaped for that application. Thanks.
Horseshoe is offline   Reply With Quote
Old 09-01-2008, 08:05 PM   #2 (permalink)
Jagfixer's Avatar
New metal lines are available. I don't think I would try flex at rear axle. Flex are for steering movement.
Larry K.
96 4.0 Discovery 1 ( 9 yrs )
96 4.6 HSE Range (3 yrs )
Jagfixer is offline   Reply With Quote
Old 09-01-2008, 08:30 PM   #3 (permalink)
KevinNY's Avatar
Atlantic British stocks the pre bent lines complete with the proper nuts.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
'91 RRC, bone stock
KevinNY is offline   Reply With Quote
Old 09-02-2008, 05:43 AM   #4 (permalink)
Any UK suppler will sell you Aeroquip (aka stainless flexible braided brake lines) for front or back. Try Rimmer, JE, Real Steel, V8 Developments, Rpi or anyone there. US suppliers seem to sell LRNA supply only.
James
bartell is offline   Reply With Quote
Old 09-02-2008, 05:53 PM   #5 (permalink)
Horseshoe's Avatar
Thanks guy's, I found them online per your tips. Can anyone explain why a short metal pipe the right side is 10 bucks and a similar short metal pipe for the left side is over 90 bucks? Guess which one I broke.
Old 09-07-2008, 08:24 AM   #6 (permalink)
are you certain they are quoting you the right one.
the fronts are cheap, but the rear is one piece.
Old 09-07-2008, 03:18 PM   #7 (permalink)
Horseshoe's Avatar
Seems to be the case. I checked several supply houses. Anyway, I bought a 3 dollar section of pipe and broke out the bender and made my own. It seems to work but I am replacing the Calipers now because they just seem too damaged to work properly so I will have to wait a bit to road test it.
Brake Line Replacement FoCoRRC Range Rover Classic 3 05-08-2008 02:36 PM
Brake Caliper Sheared Off! Help! AZROVER Discovery Series I 3 12-04-2007 02:36 PM
wheel cylinder rebuilding theclay Series Land Rovers 23 05-21-2007 05:45 PM
help! motor running on brake line system jb1rd Discovery Series I 3 05-14-2007 05:47 AM
Brake Rotors and Pads How-To werldcup Discovery Series II 4 03-23-2006 08:16 PM
