Old 02-06-2006, 01:32 AM   #1 (permalink)
Default Car Has No Electrical Power, Yet Battery Fully Charged?
really weird situation...
car acts like the battery is completely dead...no lights nothing...like the battery isnt even connected...yet when i take it off to test the battery, its fully charged, plus i have a new alternator...if i go to jump the car it wont really react, but it will give it like 3 seconds of power and the alarm "half assed" comes on, then it clicks multiple times(the clicking noise of like when your battery is dead) so i'm super confused on what could be wrong here..i checked the fuses in the engine bay and all seems to be fine..any suggestions guys? thanks
1997 Disco SE -Forest Green
K&N Air Induction System
RoverTek Performance Computer
BORLA Exhaust System
OME H/D Shocks
31'' Good Year Wrangler MT Tires
RoverTym 2'' Lift Springs
Kenwood MP3 Player
Kenwood 800W Amp
2 10' JL AUDIO Sub's In Custom Box
In Car DVD System W/ 3 6.5'' Monitors
1990 Nissan Twin Turbo 300ZX 700HP
1992 Nissan Non Turbo 300ZX 300HP
Toddicus is offline   Reply With Quote
Old 02-06-2006, 05:31 AM   #2 (permalink)
either a bad cell or a loose ground somwhere.
Double check the battery wires. test them as well.
Old 02-06-2006, 07:37 AM   #3 (permalink)
cell as in on the battery? when i take it out to charge, and shows full charge...would a battery with a bad cell still show full charge? its really strange cause the car ran fine, and then i let it sit for 3 days and it was completely dead...
OME H/D Shocks
Kenwood MP3 Player
Kenwood 800W Amp
Old 02-06-2006, 08:23 AM   #4 (permalink)
Getting the mud off.....
acornhoek's Avatar
yes.
Take the battery to your local parts store and have them give the battery a check. Also, like beezel says, check your ground wires and their contacts.
acornhoek is offline   Reply With Quote
Old 02-06-2006, 09:25 AM   #5 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Arrow Lets get busy......ATTACK!
Start with the connections on the batteries. They go bad with corrusion.
Close the inspection holes tightly. Get baking soda and pour it ontop the battery without getting it inside the battery. Metal brush. Use it on the terminals and the posts. Make sure your posts are on real tight. Rinse clean and put those cables on tight.
Does it start? If not, then replace your battery cables. You got a open somewhere.
Adam in NYC
inert facts.
Old 02-06-2006, 02:55 PM   #6 (permalink)
Check where the battery lead bolts to the chassis.
Then check the lead where it connects to the starter
TEMPL4R is offline   Reply With Quote
Old 02-07-2006, 04:41 PM   #7 (permalink)
Templar has a strong point "even if he is from Lancashire LMAO im a Yorkshireman" sounds to me the lead connecting to the starter is not right but from what you say it could be the starter itself!!! Do all the other electrical items ie lights etc work OK???
Craig is offline   Reply With Quote
Old 02-07-2006, 07:50 PM   #8 (permalink)
OkieRover's Avatar
Gallery: 2
Did anyone say fuseable links yet???
I punch my clown daily.
Old 02-08-2006, 11:37 AM   #9 (permalink)
k12
k12's Avatar
I had the same deal a few weeks ago. battery tested 11.85 volts, and when tested by a shop, they said it was about 75% good. I replaced with a 60 dollar one, and the problem is history. Get the battery tested first, before going through all this other stuff.
K
k12 is offline   Reply With Quote
Old 02-08-2006, 04:37 PM   #10 (permalink)
K
You were right in replacing your battery. A new well charged battery needs to be at 14.2 to 14.6 volts. 11.85 is a dying battery.
Mike J.
