Old 02-21-2007, 10:08 AM   #1 (permalink)
jed
jed's Avatar
Default cargo door panel, drivers door panel
how does the cargo door panel (Interior) come off?
one of the red retaining tabs broke off and it looks like it slide's off by the head
of the tab moving to the larger cut out in the panel is this it or no?
And How do I remove the drivers door panel is it the same as in this article?
http://www.erovers.com/flrc/tech/doorlocks.pdf
note just the door panel parts.
thanks for any help Jed
96 Discovery SE
72 M35A2
I'd rather push my landy then drive a cruiser!
jed is offline   Reply With Quote
Old 02-21-2007, 02:09 PM   #2 (permalink)
where am i?
moreheads's Avatar
I have a cargo latch that doesnt go all the way with the power lock. If I want to open the cargo door from the outside, I reach back, make sure the latch is all the way up, and then I can open it. Is it easy to get the interior panel off without doing any damage to it?
Thanks!
moreheads is offline   Reply With Quote
Old 02-22-2007, 06:59 AM   #3 (permalink)
Us a flat blad like a 1" putty blade and gentley pry up the cover, if you are lucky, you will only break a couple of the red clips which you can usually find at your auto parts store.
