» Sponsors
» Sponsors
Old 07-03-2009, 03:38 PM   #1 (permalink)
Default Catalytic converter
If the check light engine comes on and you get code P0420 Catalyst efficiency below threshold Bank 1, does that mean that you need to replace the Catalytic converter? I know obvious answer....I replced the plugs and O2 sensors and it has 148,000 miles on it. Any ideas??
Thanks
john
John Kuntz is offline   Reply With Quote
Old 07-03-2009, 06:44 PM   #2 (permalink)
Super Moderator
At your mileage replace them both at your local muffler shop. You didn't mention, have you replaced your plug wires?
Old 07-03-2009, 06:59 PM   #3 (permalink)
Thank you
I have replaced the plug wires about 40,000 miles ago. None of the local muffler shops will put in a catalytic converter (universal type) and two of them Midas and Monroe couldnt even find the Y Pipe through their suppliers with the two already on it. So I figured I could order the complete Y pipe with the two cats online and will just put it in. maybe it is a function of my geographical location...
Old 10-02-2009, 02:00 AM   #4 (permalink)
ema
At the rate your car's going, you should really change both. Well, here, try looking up at this catalytic converter site for replacements.
ema is offline   Reply With Quote
Old 10-07-2009, 10:47 PM   #5 (permalink)
try europartsdirect, roversnorth, rockauto and roverland.com these are some of the sites I have found with the best prices on alot of Disco stuff just be sure to check one against the other. I have found them brand new for around 450-500 bucks complete with y pipe
treasurecoastdisco is offline   Reply With Quote
exploded catalytic converter .... User Range Rover Classic 9 06-03-2009 03:52 PM
Symptoms of a bad Catalytic Converter 98GRDisco Discovery Series I 1 10-30-2008 12:33 PM
I need a new catalytic converter CurvyRover Range Rover Classic 9 11-22-2006 10:20 AM
