Support Our Troops
I have the following codes being thrown on my 97 disco
p0300 p1314 p1313 any clues?
John Conklin LRO Moderator |
Support Our Troops
Well I have a friend at a local shop that is looking at it for me and those are the codes he got from it. He checked and the spark is fine and fuel pressure is fine. He is leaning towards possible MAF, but at almost $700 I really dont want to be guessing at this and that. I started a thread about what is doing so for more details just look down a few more threads. He replaced the vac lines that were bad and I am still where we started from.
John,
The 300 is mutiple misfires, random 1313 and 1314 are failed cats. No MAF at this time. You need to start looking at what is killing your cats, plug, wires, coil, dirty injectors, coolant leaks. Mike |
#4 (permalink) | |
Support Our Troops
Cats are junk for all intents and purposes. How bad were the wires and plugs and how long ago were they replaced, they could still be the problem that killed your cats.
My only concern is that if you can't verify what killed the cats, it will happen again and that is getting expensive at that point. Mike |
#6 (permalink) | |
Support Our Troops
The plugs I changed out the begining of the month and they looked pretty normal. One or two had a little bit of oil on them, but very minor
The Urban Motorist
![]() Join Date: Sep 2004
Your cats may be contaminated. The ECU is seeing the pre and post oxygen sensors. Try to get the cats first by geting them up to operating temp.
First clear the codes off the ECU and put a fresh tank with premium and some octane booster. Run it for 30 miles LET THE CATS GET HOT. If they are good, the crap will clear out. Second, think about changing out the oxygen sensors if they have not been changed. Oxygener senors get ruined by leaded gas, oil in the exhaust, and of course old age. Adam
-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=--=-==-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Owner of a 1996 Land Rover Discovery 1 in Beluga Black or the Dirt of the Day. Where we are going,we don't need roads. Nothing in education is so astonishing as the amount of ignorance it accumulates in the form of inert facts. ‘The Education of Henry Adams’ (1907) ch. 25 |
John,
How many miles on the truck? When you say the engine is running rough, go into more detail. You may want to consider a compression test just to make sure those wet oiley plugs you replaced are not indicators of head gaskets or valves and a leak down. Mike |
#9 (permalink) | |
Support Our Troops
As for the running rough here is what happening: It is stummbling, but stays running. It stalled out on me the other morning and it took about 1/2 hour to get it to stay running without my foot on the gas. As soon as my foot was off the gas it would stall out and take a few tries to get running again. Once it was warmed up it ran pretty good, but still felt like it wasnt 100%. I talked to my friend again this morning and he said that when he disconnected the MAF sensor it ran fine and he is leaning towards that, but I really dont think that is the problem at least not the only problem. My mom had a car that had bad cats and it did the samethings that my Disco is doing, stalling, loss of power, not keeping a steady normal idle. Here is a link to what started this all, Having Trouble staying running
#10 (permalink) |
If you unplug the MAF, you are basicly turning off the ECU's ability to manage your engine, NOT GOOD.
I understand that you are wanting to try anything to get it running again, but go and try everything people tell you to do till you research it out. You have no MAF related codes so don't go there. Have you looked at the fuel system, fuel filter, relay and pressure when running at idle and 2000 RPM's as well as when turned off for an hour or so? Mike |
#11 (permalink) | |
Support Our Troops
#13 (permalink) | |
Support Our Troops
I have an exhaust leak at one of the manifolds, would that have caused my problem? I really have no clue where else to look at with this thing. I mean they say the fuel system is fine, the plugs and wire were just changed, The one vac line they changed. I have a chance to get a y-pipe with cats & o2's for free (used, but still free). Maybe I should change it out and see what happens to the codes after doing that, I am not sure.
