Old 06-09-2006, 08:20 PM   #1 (permalink)
Default Check Engine Light
Anyone know where I can start? The light came on today while pulling a small trailer (lawnmower). I usually use the pickup but used my 1996 SD instead. Fairly warm day, 95 degrees (Southern US!). Thanks for the help.
Tuco is offline   Reply With Quote
Old 06-09-2006, 08:51 PM   #2 (permalink)
A good place to start, assuming you do not have an OBD II reader, is to stop by an Autozone and ask them to read the code for you. After that, if you'll do a search for codes on this site, you'll find a webpage that lists them..or post again and someone will let you know what it means. Sometimes, it means you didn't tighten your gas cap well enough (at least three clicks) when you filled it up. But, it could be anything.
Wade
wade is offline   Reply With Quote
Old 06-10-2006, 12:07 PM   #3 (permalink)
No reader, but do have an Autozone. I'll give it a try.
Old 06-10-2006, 03:59 PM   #4 (permalink)
RoverChic's Avatar
Probably nothing major but get them codes and write them down. Maybe 02 sensors, MAFS...Any other problems with the Disco?
2006 Range Rover Sport HSE Rimini Red
2001 D2 CDL
1998 D1 ('Henry' Sold 05/05 Bought Back 01/06 Retired)
1988 RRC SWB ('Silver Bullet' Retired 05/98)
RoverChic is offline   Reply With Quote
