Old 09-03-2004, 01:18 PM   #1 (permalink)
Default Check Engine light
The check engine light on my 95 Discovery came on with a code 48.
Suggestion was to clean stepper motor and clear the faults as follows:
1) Switch Ignition ON -- Do Not Start Engine.
2) Disconnect Serial Link plug, wait 5+ seconds.
3) Re-connect Serial Link plug.
4) Switch OFF Ignition, wait for main relay to drop out (click).
5) Switch Ignition ON and check display unit for further codes to appear. Clear each as above
As this did not work I replace the stepper motor and did the same still have the problem.
Suggestions?
mossrock98 is offline   Reply With Quote
Old 09-03-2004, 01:53 PM   #2 (permalink)
beer drinking member
dent's Avatar
did it not clear the codes at all or did it come back?
take care
sam
dent is offline   Reply With Quote
Old 09-03-2004, 02:03 PM   #3 (permalink)
Did not clear at all
