Old 08-30-2004, 07:14 PM   #16 (permalink)
Default Check Engine light
It is actually the Check Engine light that's on. I cleaned the stepper motor(the end of it was covered with carbon) A'm I looking in the right place at the code under the passanges seat. It reads code 48?
mossrock98 is offline   Reply With Quote
Old 08-31-2004, 06:09 AM   #17 (permalink)
beer drinking member
dent's Avatar
Originally Posted by mossrock98
Where is the serial link mating plug?
it's the cable that connects to the box under the seat...
yes you're looking at the right spot if it read 48. After you've cleaned the idle valve, reset the codes following the directions above and keep your fingers crossed that there are not any more codes...
take care
sam
dent is offline   Reply With Quote
