I hope someone can help me here....
I have a Discovery N Reg 2.5 TDI automatic... Whilst driving the 'Check Engine' Warning light appears and the car looses all power however i can still hear the engine running. According to my local garage...the engine and gearbox are fine but the problem remains a mystery... This problem reoccurs more often when i am driving between 20-30mph, or if im accelerating for the first time..... Has this happened to anyone else?? Nat. |
I know nothing about Tdi's but did they check the throttle? When you mean you lose all power do you mean when you press the accelerator nothing happens? Just sounds like your throttle is having problems because you said your engine remains on and idleing.
"Good saddles ain't cheap, and cheap saddles ain't good." |
The Best 4X4XFar
It won't be the throttle I wouldn't have thought, diesels don't have a throttle body or TB blade. The throttle linkage is massive and very robust and mounted onto the Bosch injector pump.
Land Rover Discovery (3 Door) 200Tdi 5-speed ![]() Mods:Allisport LARGE FMIC | Allisport Tuned | Simex Jungle Trekker II 33.11.50R15 Tyres | 15x8 8 Spokes | Heavy Duty Uprated Suspension (shocks & springs) | Wheel arch Flares | 1" Wheel Spacers | Custom Straight Thru Exhaust | Custom Trimmed Front bumper with twin NATO Hooks | Custom Rear Bumper with single Large NATO Hook 360˚ Swival | Front Light Guards | Custom Aluminium Rear Floor | Bonnet Straps | 100w Spot Lights | Upgraded Headlights The Best 4X4XFar |
#4 (permalink) | |
The Best 4X4XFar
Also diesel auto's are pretty rare. And I'm also going to guess you have one of the very few ECU controlled 300tdi's. Most ECU (electronic control unit) setups will have a "limp" mode where it detects something wrong and reduces engine power and rpms to prevent damage, often this is triggered by a faulty sensor as opposed to something wrong. Of course it may not be this, do you have any more info? Like what happens to the rpms when this happens? Could it be the gearbox slipping? How long does it take to recover? What happens when it does recover? Other things to check: fuel - if there's a faulty injector it would reduce flow. Or if the injector pump is faulty (very rare and not likely). air - I had this probelm on a Peugeot. There was a small split in the fuel line and under load it was allowing air to be sucked in, this effectively stalled the engine as it kept running out of fuel Who have you had look at your Discovery and what part of the coutry are you in? I might be able to recommend some one to help you out.
#5 (permalink) | |
Hi there Many thanks for your advice and you guessed right i'm from the UK. I also think it could be the gearbox slipping too however my local garage seem very relunctant to do anything about it... It only happens for a few seconds, and the RPMs drops. Once its over it changes gear and runs back to normal... I've taken in it to our local LV garage in Luton in the past but due to a number of bad experiences I dont really want to go there again...So I would be grateful if you could recommend someone/garage. Once again thanks for your advice!!! The mystery will be solved.......eventually! |
#6 (permalink) | |
The Best 4X4XFar
Sadly diagnosing a fault can be a pain and costly. It might be worth a phone call or visit here:http://www.woodside-landrovers.co.uk/ It's a private run Land Rover Specialist. The own Mark Smith used to be the Service manage at Dunham & Haynes in Luton (the Land Rover dealership before they where bought out by the current owner). He is very helpful and very knowledgeable. Woodside Garage (Maulden) Ltd, Clophill Road, Maulden, Bedfordshire, MK45 2AE Tel: 01525 862727 Mobile: 07876 440707 He is based only just down the A6 about 15mins from Luton, if you know the area you just need to head up the A6 from Luton towards Bedford, at the Clophill round-about (there's a Beefeater there - The Flying Horse I think) turn left towards Ampthill. About a 100 yards down turn right. Follow the road round a tight left hand bend about 50 yards ahead, just as you come out of the bend there is a dirt track/yard entrance on your right. Woodside gagrage should have a sign there. Just follow the track down to the bottom and he should be on your left the last unit in the yard.
#7 (permalink) | |
Thanks alot for your recommendation, i'm going to give them a call this afternoon....Fingers crossed that all will be resolved!!! Nat |
