Old 03-15-2005, 10:56 PM   #1 (permalink)
Exclamation clearance valve adjustment
Hello! Could you pliz give me the maintenance manual for Discovery I, 1995, 2.5TDI??? I need to adjust valve clearance in engine and fail to find relted information in Almaty, Kazakhstan. I will appreciate any link or electronic manual at email.
Thank you in advance.
valerik is offline   Reply With Quote
Old 03-17-2005, 01:13 AM   #2 (permalink)
Default Adjusting vales on 2.5 tdi
The valve clearance on the 2.5 diesel is 0.20mm (inlet and exhaust).
aussie disco97 is offline   Reply With Quote
Old 03-17-2005, 01:18 AM   #3 (permalink)
Thank you very much!
Old 03-17-2005, 01:38 AM   #4 (permalink)
Default Re Valve clearance
If you want to purchase a workshop manual. I have found the Haynes are really good ( I also have the genuine Landrover Manual) they are reasonably priced , so you don,t mind jotting in notes eg manual gearbox fillplug is a Torx t55 and the post 97 swivel pin housing has grease not oil etc.If you want to chase one up go to www.haynes.co.uk .It really is an excellent product for the price.
