Clicking relay - no start - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 5 (permalink) Old 02-23-2011, 02:00 PM Thread Starter
Quoted: 0 Post(s)
Hi again all. I'm hoping someone will have an idea on this situation. when I tried to start the engine a relay under the glove box of my 1998 Disco 4.0 began clicking rapidly and it wouldn't turn over at first but did after a few seconds but wouldn't start. I left the key in the ignition position to try and locate the sound. After a minute the clicking stopped and I tried it again and it worked. Later that day it started clicking again but this time wouldn't stop. Now the engine turns over sometimes and other times it doesn't. When it turns over however it won't start. I found the relay in a yellow box, removed the relay, took it apart and gave it a cleaning, and replaced it with no difference. I'm going through the RAVE manual over the past two days and can't find the relay to trace the circuit.
The battery is new. It's not the clicking that accompanies the starter with a weak battery. The clicking comes on when the key is in the second or ignition position, not in the third or starting position although it will stay on while cranking the engine.
Any help would be greatly appreciated. Thanks
Piranhaboy is offline
post #2 of 5 (permalink) Old 02-23-2011, 02:05 PM
Quoted: 11 Post(s)
Use the wire colors on the relay base to guide you in the ETM.
Yes, I am still alive, and still in the Rover parts business.
Text me for greatest likelihood of finding me.
260-804-0458
Dominic Perodeau/Global British is a thieving bastard, do not send him money.
PTSchram is offline
post #3 of 5 (permalink) Old 05-10-2011, 09:36 AM
97 Disco SE
Quoted: 0 Post(s)
clicking relay
Hey pirhana boy,
DId you ever solve the clicking relay problem? I'm having the same issue and i'm looking fo ideas....?
montanarover is offline
post #4 of 5 (permalink) Old 05-04-2012, 02:13 PM
Rover-Fixer-Upper
area51Rover's Avatar
Quoted: 0 Post(s)
Same here
I have the exact same issue... it has to be water in an inportant box like the ECU... reason being, I have two bad hols in my front fenders blasting water up into the engine compartment as I drive.
"DIY I always say!"
area51Rover is offline
post #5 of 5 (permalink) Old 05-05-2012, 11:33 PM
Rover-Fixer-Upper
Quoted: 0 Post(s)
Took ECM apart... Found Salt!!
Yesterday I took the ECM apart (located under the hood between washer resevior and fender PS)
It was Full of salt that acumulated through 3 drain hols in the bottom corner. I guess salt in solution with water from the road in winter was splashing onto the bottom of the ECM because of the rust hole in my wheel well PS. once inside the water drained out and the salt cristalized again.
So I Cleaned it out and there is no visual damage to any circuit components or the board but it was pretty obvious it was shorting some contacts ( i think salt is very conductive)
Once it was fixed up and put back in the same issue and the alarm was also going off until I pulled the positive from the battery.
Is my ECM screwed now?
"DIY I always say!"
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Temp. sensor for cold start relay. jcav Range Rover P38, Mk III and Range Rover Sport 0 01-30-2011 09:40 AM
Fuel Pump Relay clicking on shut down yo-cello Discovery Series I 1 11-24-2010 02:08 PM
94 RRC fuel Pump relay?,will not start oarspi82 Range Rover Classic 17 03-17-2010 05:46 PM
No Start problem solenoid relay? ignition switch? MysteryTheatre Range Rover Classic 2 08-01-2008 10:51 AM
hard start/fuel pump relay armydisco Discovery Series II 13 05-04-2007 02:39 PM
You may post new threads
You may post replies
