MG
![]() Join Date: Aug 2005
Hey everyone!
My clutch is starting to slip, so I know that I'll have to drop the gearbox to see what the deal is. I've got the Haynes and Workshop manuals, so I have a good idea of what is involved, but was hoping to know if there are any pointers from yawl. While I have the gearbox down, is there any other PM I can do? TIA!!
________________________ MG '95 Disco I, 3.9L V8i 5-speed Discoverying Bolivia... |
![]() Join Date: Dec 2005
What do you plan to replace? If it is slipping look at the pressure plate surface and see if it is good enough to reuse, then again, it might be best to replace the pressure plate, clutch disc, and if you really want to, the pilot bearing.
I was told a trick on how to remove that silly little thing; take tissue paper and jam it in there and take a socket that will fit the hole and press hard, and believe it or not, the pilot comes out. An old instuctor showed us on a 350 Chevy. Look also at your flywheel, and if it is near shiny as a mirror, use emory cloth to rough it up a bit and to clean it so the new clutch has something better to grab to. If it is really rough and beat up like an old brake rotor, you might have to remove it and take it to a shop to have it resurfaced. You can use brake cleaner to clean the surface of the new pressure plate and flywheel, kinda like a brake job. That's my 2 cents. Have fun man! ![]()
Pat Albaugh, Midwest Moderator "Diffage" -the point at which the truck's differential makes contact with the ground. http://www.cardomain.com/id/RageRover42Visit my RRC and others here!(updated as of September 15, 2006) 1995 RRC LWB -LT265/75R16 Pathfinder All Terrains -RTE 2" Lift Springs -Pro Comp ES9000 Shocks (from DAP Enterprises) -KMC Front Diff Guard -4 Desert Fox 55 watt Lighting -Radio Shack CB Radio (never know when signal fails on a cell phone) -2 Halogen Super Sport 100 watt forward lights -Brush Gaurd, meant for a Jeep Grand Cherokee, now fitted to the RRC -Lowe's Special "Homemade" Snorkel -T-Case out of an 92' RRC |
MG
Thanks Rage! I'm not sure why it's slipping, so I don't know exactly what I'll have to swap out. I'm afraid of replacement parts here, though. A buddy of mine is travelling down on business, so I want to have him come with the parts I need. I just may do all three of them you mentioned.
The Workshop Manual says I'll need a clutch centralising tool (LRT-12-001). Can I get the job done without it?
Not knowing what your mileage is on the truck and how hard you work it off the road, I am going to suggest you buy a complete kit and replace everything. Don't reuse parts, that is like using a condom for the second or third time, it doesn't work.
Check the slave for leaks, bleed the clutch fluid, and resurface the flywheel if there are any hot spots showing. Check and replace the engine rear main seal if it is showing any seapage as well as other seals such as the trannt front seal. Remember after the job is done, break the clutch in easily to assure long wear. Mike |
RageRover - your pilot bearing removal trick sounds very good but I don't follow how it works...Is the loose fitting socket forcing the tissue paper against the back edge of the bearing and pushing it out, or is the tissue paper simply filling in the gap between the socket and the bearing working surface (making a real tight fit). Could you explain a bit more please! Thanks.
Pavel, what the instructor did, was just randomly jam tissue paper in the hole, and start pushing hard on the socket and the tissue pushes out the back of the pilot bearing and forces it out.
