In my Disco I 1994 the box under the pass. seat says (48).
All the codes that I have heard of are longer than that. Any ideas as to what this is meaning- what is wrong? Thanks! |
Here you go.
Mike Quote: Land Rover FAQ: Part IV, Engine Fault Codes Note: This information is for the 4.0 liter V-8 OBD I (On Board Diagnostics, phase I) Petrol engine that is found in the US. The information may hold for other markets and engines, but we cannot confirm this. It may also be true for Defenders and Range Rovers with the same engine. Again we don't know NAS Discoveries have a digital readout for diagnostics. It is a black plastic box measuring approximately 1" x 2.5" x 3" with a red LED readout. It is found under the passenger seat facing backwards. It may be unclipped and moved so that the driver can see it. This doesn't give nearly as detailed readout at the official test box, but it's better than nothing. Fault Codes Jump directly to the fault code: 02 12 14 17 18 19 21 23 25 28 29 34 36 40 44 45 48 50 58 59 68 69 88 General: * The fault codes are given in order of priority. If more than fault exists, you have to clear the display before the next fault code can be displayed. * Fault code 02 meas that the ECU has just been reconnected. Switch on the ignition to clear the display. Clearing the display 1. Switch ignition on. 2. Disconnect serial link mating plug, wait 5 seconds, then reconnect. 3. Switch ignition off, wait for main relay to drop out. 4. Switch ignition on. The display should now be reset. If there are other faults, the next one will be displayed. Otherwise the display will be black 5. If there is more than one fault repeat steps 1 to 4, to clear each fault until the display is blank. No LED's are on: Good news; nothing is wrong. Either that or Mr. Lucas has struck and either the LEDs are burned out or the display isn't getting any power. Code 29 - ECU memory check If detected all other faults are unreliable and must be ignored. Procedure: 1. leave battery connected 2. switch ignition off 3. wait for approximately 5 seconds 4. disconnect ECU plug. 5. reconnect ECU plug 6. switch ignition on and check display unit. If fault code 29 is detected again, swap out the ECU for another one and retest. Code 44 - Lambda sensor A - left bank Code 45 - Lambda sensor B - right bank If one of these fault codes is displayed check the wiring to that particular lambda sensor. If both codes are displayed, the voltage supply to the heater coils of the sensors must be checked. Refer to test 26, continuity test procedure. Code 25 - Ignition misfire This code indicates that an ignition system misfire has been detected. Codes 40 or 50 indicate on which bank the misfire has occurred. Code 40 - Misfire bank A - left bank Code 50 - Misfire bank B - right bank If both codes are displayed, check the following components common to both banks: Distributor cap Rotor arm Coil Electrical connections Pick-up (air gap) Amplifier Injectors (if code 34 or 36 is displayed) If either fault code 40 or 50 is displayed check components applicable to the particular bank that the misfire has occurred on. Spark plugs HT leads Distributor cap Injectors - if code 34 bank A or 36 bank B displayed Code 12 - Airflow meter Refer to test 19, continuity test procedure. Code 21 - fuel tune select Identifies that the tune select resistor is open circuit- refer to tune select resistor test. Code 34 - Injector bank A The display will indicate if the injector(s) are causing the engine to run rich or lean. If the bank is running rich, check for - faulty injector wiring and connectors, stuck open injectors. If the bank is running lean, check for - faulty injector wiring and connectors, blocked injectors. Code 36 - Injector bank B As code 34, except relevant to bank A injectors. Code 14 - Coolant thermistor Refer to test 14, continuity test procedure. Code 17 - Throttle potentiometer Refer to test 17, continuity test procedure. Code 18 - Throttle potentiometer input high/airflow meter low refer to tests 17, 18, and 19 of the continuity test procedure. Code 19 - Throttle potentiometer input low/airflow meter high refer to tests 17, 18, and 19 of the continuity test procedure. Code 88 - Purge valve leak refer to test 9 and 10 of the continuity test procedure. Code 28 - Air leak check for air leaks in the following areas: o Hose, air flow meter to plenum o Breather system hoses to plenum o Brake servo hose o Vacuum reservoir hose (fresh air solenoid) o Distributor vacuum advance o Hose, purge valve to plenum o Injector seals o Joint - bypass air valve to plenum plenum chamber to ram housing ram housing to inlet manifold inlet manifold to cylinder head bypass air valve hose Code 23 - Fuel supply check fuel system pressure, test 20 of continuity test procedure. Code 48 - Stepper motor check base idle speed- see setting procedure. Refer to tests 15 and 16 of continuity test procedure. Check road speed sensor- refer to test 25 of continuity test procedure. Code 68 - Road speed sensor refer to test 25 of continuity test procedure. Code 69 Gear switch refer to test 24 of continuity test procedure. Code 58 Group faults 23/28 This indicates that a fault has been registered that is caused by the fuel spply or an air leak but the exact fault cannot be identified. Check all items outlined under codes 23 and 28. Code 59 Fuel thermistor Refer to test 13 of the continuity test procedure. |
Thanks!! I actually bought a used TPS for her since she is idling all over the board and stalling during almost every turn I make!
Thanks again! ps. does anyone know where I can buy a nice used VSS? speed sensor, not the kind that go in the wheel for a Disco I 1994? We've checked all the 'regular' used part places online. Thanks! |
Why a VSS? What testing do you do to confirm it failed? Did you know you can test it?
Test, dont guess.... Work the problem, do a solid diagnosis and fix the car.
I only worry about myself, screw the others. |
| Thread Tools | |
| Display Modes | |
| Code 1176 Maximum Positive FMFR Correction Fault Disco I | wade | Discovery Series I | 9 | 04-24-2008 02:14 PM |
| Flooded Radio wants Code | RJG18 | Discovery Series II | 4 | 09-01-2006 05:06 AM |
| code 12 | jblackbu01 | Range Rover Classic | 9 | 09-02-2005 08:27 AM |
| Code... P1178? | texasrover | Discovery Series I | 4 | 07-07-2005 11:40 AM |
| ABS Code | OkieRover | Range Rover Classic | 4 | 06-26-2005 05:58 PM |
