Old 08-24-2008, 07:10 AM   #1 (permalink)
Gallery: 1
Default Codes P1187, P1179 and P1177
Got the following codes tossed at me,
P1187 Oxygen Sensor Heater Circuit Short Upstream
P1179 Maximum Negative AMFR Correction Fault
P1177 Maximum Negative FMFR Correction Fault
I also picked up a new Vacuum tester and a new fuel pressure tester and will be giving the truck a good go over hopefully this afternoon if the rain holds off.
Ordered a pair of front oxygen sensors and will replace them both since I'm not sure which would be bad. I found a source that has direct plug in replacements (Including the plug) for 56.69 each.
He has one left...
eBay Motors: O2 Oxygen Sensor Land Rover Discovery Range Rover 14788 (item 140259351576 end time Aug-25-08 09:08:12 PDT)
For the price, I figured I would take a shot and see how it turns out.
Also, I found a company that sells the MAS for 45.00 GBP plus £9.00 GBP shipping for a total of £54.00 GBP (about 125 bucks us)
Range Rover Discovery air flow meter sensor.ERR5595A on eBay, also, Land Rover, Car Parts, Cars, Parts Vehicles (end time 27-Aug-08 15:31:29 BST)
The listing is for the exact part number listed on my original MAS (Sagem ERR 5595A) and the price was cheap enough to give it a shot. The MAS I took out of the juckyard 96 I found does seem to be working fine, but is not the exact same part. I guess it's not bad to have a spare anyways since I also bought that 98.
I'll report back on both parts, etc so other can use the information as to wether or not I get screwed...
cgerrells is offline   Reply With Quote
Rough Start, Stalling, Error Codes ONBELAY Discovery Series I 9 03-14-2007 10:46 PM
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 08:00 AM
obd two codes Rovin4life Discovery Series I 4 12-25-2006 10:16 AM
