Old 09-18-2004, 07:56 PM   #1 (permalink)
Question condensation?
Hello all,
I just bought a 1996 Discovery and have noticed condensation when going uphill. I also noticed a decrease in power when this happens. It happens either with the ac on or off, but comes from the vents in the middle. It appears to be from ac or radiator (?).
Thanks to any help or suggestions.
new owner
mddeje is offline   Reply With Quote
Old 09-19-2004, 08:36 AM   #2 (permalink)
Does it smell sweet, if so it is the heater core leaking coolant. If there is no sweet smell your A/C vent tubes are plugged up which is an easy fix. Either way this should not effect the power of your truck.
Mike J.
Old 09-19-2004, 08:54 AM   #3 (permalink)
Smile heater core leaking coolant?
Thanks Disco Mike,
If it's the heater core leaking coolant, would it eventually get worse if not fixed?
new owner
Old 09-20-2004, 01:01 PM   #4 (permalink)
I think I have the same problem with my 99 RR. I smell what I believe to be antifreeze coming through the vents. I just bought the car!!! I see the part alone is almost $400.
Robrover is offline   Reply With Quote
Old 09-20-2004, 02:37 PM   #5 (permalink)
You don't want to let a heater core leak too long, it will ruin your carpet.
Mike J.
Old 09-20-2004, 03:02 PM   #6 (permalink)
And it can worsen very quickly, usually when you don't need it to. I had one blow out onto my feet, Pleasant!!
mbruneaux is offline   Reply With Quote
Old 09-20-2004, 04:05 PM   #7 (permalink)
V8_Agro's Avatar
My 93 Disco heater core went and its no small job it took the landrover mech 7 hours to do as the core is bolted to dash and the dash is one unit
Adam
undefined
Oh behave
99 Defender 130 C/C
98 V8 Disco RIP
93 V8 Disco RIP
80 V8 Stage 1 RIP
V8_Agro is offline   Reply With Quote
Old 09-20-2004, 05:19 PM   #8 (permalink)
My carpets are not damp or wet nor do they smell. I am hopefull could it be something else? Just bought the damn truck and don't want to spend $1000 right now.
