Old 08-06-2005, 08:07 PM   #1 (permalink)
Default Condenser and Radiator fan problem
The two electric fans behind my grill do not work.
I checked each by connecting them directly to the battery and they both work fine.
I also jumped the two leads going to the sensor on the thermostat housing and they still failed to switch on.
I'm at a loss as to which relays are the ones connected to these fans and where they might be located. If and when I find them I'd like to check them and replace them if neccesary.
Can anyone tel me where theyt might be found and how to do this?
Also if anyone has an idea as to why the fans migh not be working please let me know.
Is there a secret fuse somewhere????
Thanks
Eric
95 Disco 173K miles
62sunbeam is offline   Reply With Quote
Old 08-07-2005, 02:04 PM   #2 (permalink)
Black Magic's Avatar
The AC has to be turned on, the ignition turned on, and the interior fan switch on "1" or above for them to operate.
Black '02 Discover SII, Auto.
Black '87 Suzuki Samurai, rock crawler :
Black '94 Discovery SI V8i, 5 spd (Currently DOA)
--## If you have enough time to do something over again, you had enough time to do it right the first time. ##--
Black Magic is offline   Reply With Quote
Old 08-07-2005, 04:31 PM   #3 (permalink)
The slider switch for my AC is faulty and needs to be replaced that may be why the one fan does not come on for the AC but the other one should come on when the engine gets hot but it doesn't at all.
Would the relays for these fans be on the driver's side or the passenger side (USA)?
Thanks
Eric
95 Disco 173K miles
Old 08-08-2005, 08:17 PM   #4 (permalink)
Hmm - OK - I think I need to look at mine then - I thought both ran with the AC only, but I did not look that hard
Old 08-09-2005, 09:36 PM   #5 (permalink)
Checked it out tonight and both fans run when temp is low, AC is on, and fan is 1 or above - looks like the air circ fan switch might be your culprit
Old 08-10-2005, 09:02 PM   #6 (permalink)
bad swithc does't help but it turns out it was the relay.
Thanks
Eric
95 Disco 173K miles
Old 08-12-2005, 10:30 AM   #7 (permalink)
Default bad relay
I have the same problem on my discovery.
My engin is overheating when AC is on, and both fans do not work when AC switch is on.
Where did you find the faulty relay?
Maybe I need to replace mine
Please e-mail me at yosefbenloulu@adelphia.net
Thanks
yosi is offline   Reply With Quote
Old 11-17-2006, 07:26 PM   #8 (permalink)
My fans aren't working either. Can someone tell me where the relay and/ or switches are so I can start to trace the problem?
I have a 97 Disco [USA].
Oh, and this looks like a great forum. I can't believe I didn't find it sooner...could have saved me a lot of money.
brookester is offline   Reply With Quote
Old 11-17-2006, 10:05 PM   #9 (permalink)
100 quids for a days work son..
siam's Avatar
the relay is in the kick panel front passenger.. which one out of the cluster.. that's a good question..
SupermotoUSA 917
www.DiceRacing.com
RRC beast sold
Disco 95 5 on the floor
siam is offline   Reply With Quote
Old 11-18-2006, 02:49 PM   #10 (permalink)
Thanks, I tried that and no luck. Where do you think I should look next? Is there a temp switch somewhere?
Old 11-18-2006, 05:44 PM   #11 (permalink)
fivespddisco's Avatar
Gallery: 10
i had a broken wire to mine it got pinched by the rad housing
Check out WWW.Lucky8LLc.com 716-898-8153 Justin
fivespddisco is offline   Reply With Quote
Old 11-18-2006, 05:53 PM   #12 (permalink)
Hmm, did you get to the wire. Through the front grill?
