Old 03-01-2008, 03:30 AM   #1 (permalink)
Default conventional or synthetic oil?
Hi,
I have a 97 Disco I (79,000 miles) and I just changed my oil. While I was changing it, I thought about switching to Mobile 1 or a synthetic blend of real oil and synthetic. My question is, on my next oil change, would it damage my engine if I put Mobile 1 or a synthetic blend in the engine?
What are the pros and cons?
chrisusvi
chrisusvi is offline   Reply With Quote
Old 03-01-2008, 09:07 AM   #2 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
No it wouldn't damage it. Cons are price, and if you have leaks, you will leak faster. Pros are better winter operation, more stable under high heat and a higher shear strength. Possibly better mileage, but no promises.
Jim Hall
obstacle.” Michael
Old 03-01-2008, 09:56 AM   #3 (permalink)
Ello gu day mate ow r u?
r0cj0c's Avatar
Default oil
I have used Mobil 1 for trucks and suvs since i got my 97 disco a couple years ago. and i have had no problems with it. runs great.
97 Disco1 128,000
Rebuilt heads up
OME DEFENDER STEERING STABILIZER
HD DRAG LINK
RTE STABILIZER RELOCATION KIT
PROCOMP HD +2 SHOCKS
BB 2" LIFT SPRINGS
4" extended brakelines
4 stock Firestone Destination A/T
Optima Red Top
r0cj0c is offline   Reply With Quote
Old 03-01-2008, 01:00 PM   #4 (permalink)
msggunny's Avatar
Gallery: 5
My 97 has 74k on it now, i use Royal Purple 10w 40. No problems, no new leaks.
It is a bit more expensive, and hopefully i get what i pay for. supposedly you dont have to change it as often as dino oil either but i still do the 3k change.
77 SIII 88
97 D1 5 speed
91 D1 5 speed (the first, but gone )
the lord is my weapon
and i see him shoot pawns
woman is the devil
your god is a fraud
msggunny is offline   Reply With Quote
Old 03-01-2008, 02:55 PM   #5 (permalink)
I read that its a good idea to flush the engine with 6 quarts of ATF, for 20 minutes, prior to switching to a synthetic oil. Is this a good idea?
Thanks.
chrisusvi
Old 03-01-2008, 04:41 PM   #6 (permalink)
Ian Matthews
p76rangie's Avatar
Thanks.
chrisusvi
It is not a good idea to be putting through ATF. People suggest this to desludge a motor. What they don't take into account is how the sludge gets out of the oil galleries. It gets out past bearings, lifters, cams, etc. I can destroy these components and significantly reduce engine life.
Old 03-01-2008, 05:58 PM   #7 (permalink)
Elemental's Avatar
OiL
Enjoy.
Sludge! If you ahve to clean out sludge from your engine, your engine wasnt maintained.
Who told you to run 6 Quarts of ATF in your engine as a prep for Syn oil? Whatever that person tells you in future....Ignore it.
Switching from Dead dino to syn on a healthy engine will do nothing bad. If something fails(Gaskets..Clogged oil port,etc) it wasn't the oil that caused it, it was the oil that brought the marginal part to light.
When I was done with her, her bed needed Shamwow sheets!
Old 03-01-2008, 08:08 PM   #8 (permalink)
Ian Matthews
p76rangie's Avatar
Originally Posted by Elemental View Post
OiL
Enjoy.
Still pushing the same old line Ele.
Old 03-02-2008, 04:19 AM   #9 (permalink)
I just thought about oil filters. When switching to Mobil 1, does the type of oil filter have to change also?
Old 03-02-2008, 04:37 AM   #10 (permalink)
Ian Matthews
p76rangie's Avatar
No. But that depends on whether you are using a decent oil filter now. Would be a bit pointless to spend a large amount on good oil and then use a cheap filter. But then again you should not use a cheap filter with cheap oil either.
ou may find this a interesting read
Oil Filters Revealed - MiniMopar Resources
Old 03-02-2008, 10:18 AM   #11 (permalink)
Rocky Mountain High
Funrover's Avatar
I run Mobil 1 and love it. Will always pay the extra to run it!
Old 03-02-2008, 04:25 PM   #12 (permalink)
Elemental's Avatar
Thats just like askign Chris Columbus if he still thinks the Earth is round.
I am going wtih the same line, because its true.
Old 03-02-2008, 04:51 PM   #13 (permalink)
Ian Matthews
p76rangie's Avatar
But you have been proved to make statements about things you know very little about. Oil is one of those areas.
Old 03-02-2008, 06:43 PM   #14 (permalink)
Elemental's Avatar
Yeah, I dont know anythign about oil!! You know better.
Old 03-02-2008, 10:17 PM   #15 (permalink)
Ian Matthews
p76rangie's Avatar
You have proven this time and time again. You just read something on the internet by another expert and take it as gospel.
These articles might indicate that black is bad. That is, your own references state that there is only so much soot and other nasty things that the oil can hold. Once it reaches its limit, it will cause sludge. These articles also highlight that there are many other factors causing the oil to change colour. Again you just want to home in on one small point and then decide that the whole world revolves around it. Start seeing the forest rather than just the trees.
http://www.nytimes.com/2007/02/04/au...es&oref=slogin
Second Opinion: Oil Sludge: an expensive but preventable disaster
Sludge
Changing to synthetic oil? jimbob4207 Discovery Series I 8 06-10-2007 10:29 AM
Synthetic winch line. TN-LR3 Accessories 28 04-12-2006 07:11 AM
Synthetic Oil DiscoVol01 General Land Rover Discussion 9 12-08-2005 04:16 PM
Dynaflex Synthetic Winch Lines Starting @ $280.00 RedRhinoProducts Land Rover Parts and Accessories 0 11-04-2004 06:08 AM
Hot Rod V8 and Synthetic oil mbruneaux Discovery Series II 1 09-14-2004 10:02 PM
