Old 06-05-2006, 12:38 PM   #1 (permalink)
Default Coolant Failure warning.
On top of the thermostat housing and on top of the radiator there is a Black plastic plug, it’s the one you take out to bleed the system. These plugs are prone to failure without warning allowing your water to make a quick exit, sometimes apparently too quick to give you a overheating warning.
If you have no water how can the water temp gauge show it to be hot?
It’s generally accepted that the cause of failure is the plugs being over tightened previously.
These plugs cost around £1.50 each (2 dollars?) and (speaking from experience) should be changed while it’s still your idea.
Now I find out you can also get Brass replacements’
Sean
Perhaps we could start a new thread, things to mend before they break.
4x4disco is offline   Reply With Quote
Old 06-05-2006, 12:41 PM   #2 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Always keep a spare in my toolbox!
Old 06-06-2006, 12:56 AM   #3 (permalink)
Magicly Delicious
Bene's Avatar
brass plugs are availible *thumbs up*
Kevin
1994 Discovery
