well I know when I lifted my TJ I corrected my speedometer with no speedo gears. How do I correct this issue with my DI? Is this done by computer or is there a gear that needs to be changed and is it even possible?
Thanks ![]()
"He who has a 'why' to live, can bear with almost any 'how'." - Friedrich Nietzsche (1844-1900) |
Ian Matthews
You can get electronic speedo correction devices. Some actually have a switch on them so you can run road and off road tyres of different sizes and keep the speedo correct. Just do a search on the net.
Verify the spedo is wrong first.
With my 1995 classic it read atleast 10% low. After my lift and changing from 205/80 29" to 235/85 32" my speedo was dead on!!! So the conspiracy side of me says... wow my warranty ended 10% early mileage wise. Plus as a Firefighter/EMT don't you have a get out of jail free card!
Todd Carpe Rangius Roverum |
#5 (permalink) | |
It's o.k. nothing big happened between 50k and 55k.
I haven't yet. Don't even have bigger tires yet but figured it would be an issue once I did.
Thanks guys
#9 (permalink) | |
After the tire change, which happened in Colorado, I happened upon another trailer and it was dead on. By the way natyboy, your Disco I has more similar to the 1995 Range Rover than the Disco II.
#10 (permalink) |
My D1 reads almost right with 7.50x16's according to my GPS.
Tom Rowe Atlanta, GA Four wheel drive allows you to get stuck in places even more inaccessible. 62 88 reg 67 NADA x2 74 Air Portable - The Antichrist (tag 6A666) 95 D1 - R380 95 D90 - R380 |
#12 (permalink) |
The Best 4X4XFar
GPS is an easy way to check.
Also A D1 should be a mechanical speedo so depending on what's done swapping the speedo drive gear should get you closer to accurate. Either that or just don't worry about it. My speedo reads way low, at an indicated 22mph it is actually going over 30mph, sure it only gets worse as speed increases.
Land Rover Discovery (3 Door) 200Tdi 5-speed ![]() Mods:Allisport LARGE FMIC | Allisport Tuned | Simex Jungle Trekker II 33.11.50R15 Tyres | 15x8 8 Spokes | Heavy Duty Uprated Suspension (shocks & springs) | Wheel arch Flares | 1" Wheel Spacers | Custom Straight Thru Exhaust | Custom Trimmed Front bumper with twin NATO Hooks | Custom Rear Bumper with single Large NATO Hook 360˚ Swival | Front Light Guards | Custom Aluminium Rear Floor | Bonnet Straps | 100w Spot Lights | Upgraded Headlights The Best 4X4XFar |
#13 (permalink) |
100 quids for a days work son..
Disco 1 went to a 265/85/16 a whole lot taller than stock but when I guage it with those speed signs with the speedo clock on it 30 on my speedo is dead on 30mph on the sign...
