Old 01-10-2007, 05:14 PM   #1 (permalink)
natvboy's Avatar
Default correcting mph reading ...
well I know when I lifted my TJ I corrected my speedometer with no speedo gears. How do I correct this issue with my DI? Is this done by computer or is there a gear that needs to be changed and is it even possible?
Thanks
"He who has a 'why' to live, can bear with almost any 'how'." - Friedrich Nietzsche (1844-1900)
natvboy is offline   Reply With Quote
Old 01-10-2007, 06:22 PM   #2 (permalink)
Ian Matthews
p76rangie's Avatar
You can get electronic speedo correction devices. Some actually have a switch on them so you can run road and off road tyres of different sizes and keep the speedo correct. Just do a search on the net.
Old 01-10-2007, 07:54 PM   #3 (permalink)
Thor's Avatar
Verify the spedo is wrong first.
With my 1995 classic it read atleast 10% low. After my lift and changing from 205/80 29" to 235/85 32" my speedo was dead on!!! So the conspiracy side of me says... wow my warranty ended 10% early mileage wise.
Plus as a Firefighter/EMT don't you have a get out of jail free card!
Todd
Carpe Rangius Roverum
Old 01-10-2007, 08:19 PM   #4 (permalink)
That works both ways. My D2 speedo was right on, when I put bigger tires on it slowed it 10% so I got extra warranty miles....heheh.
jhmover is offline   Reply With Quote
Old 01-10-2007, 09:40 PM   #5 (permalink)
Thor's Avatar
Merry Christmas... enjoy my 10%..hahaha
It's o.k. nothing big happened between 50k and 55k.
Todd
Old 01-10-2007, 09:45 PM   #6 (permalink)
Ian Matthews
p76rangie's Avatar
How did you check that your speedo was wrong?
Old 01-11-2007, 05:07 AM   #7 (permalink)
natvboy's Avatar
I haven't yet. Don't even have bigger tires yet but figured it would be an issue once I did.
Thanks guys
Old 01-11-2007, 05:19 AM   #8 (permalink)
Ian Matthews
p76rangie's Avatar
Natv, my question was more directed at Thor.
Old 01-11-2007, 05:26 AM   #9 (permalink)
Thor's Avatar
I lived in Albuquerque at the time, where my good friend from college was a sheriff's deputy so he clocked me. I had him do this because near the Albuquerque international airport a trailer with a radar gun and a speed display was set up to show you how fast you were going compared to the speed limit sign next to it, and that seemed to read a bit low for my RR.
After the tire change, which happened in Colorado, I happened upon another trailer and it was dead on.
By the way natyboy, your Disco I has more similar to the 1995 Range Rover than the Disco II.
Todd
Old 01-11-2007, 06:08 AM   #10 (permalink)
antichrist's Avatar
My D1 reads almost right with 7.50x16's according to my GPS.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 01-11-2007, 09:19 AM   #11 (permalink)
rmuller's Avatar
My D2 is off... 32" tires.. if the speedo says i'm going 60, i'm really going 65... I measured with GPS.
Old 01-12-2007, 03:43 AM   #12 (permalink)
The Best 4X4XFar
300bhp/ton's Avatar
GPS is an easy way to check.
Also A D1 should be a mechanical speedo so depending on what's done swapping the speedo drive gear should get you closer to accurate.
Either that or just don't worry about it.
My speedo reads way low, at an indicated 22mph it is actually going over 30mph, sure it only gets worse as speed increases.
The Best 4X4XFar
Old 01-19-2007, 03:22 PM   #13 (permalink)
100 quids for a days work son..
siam's Avatar
Disco 1 went to a 265/85/16 a whole lot taller than stock but when I guage it with those speed signs with the speedo clock on it 30 on my speedo is dead on 30mph on the sign...
SupermotoUSA 917
www.DiceRacing.com
RRC beast sold
Disco 95 5 on the floor
siam is offline   Reply With Quote
